Is it possible to insert a newly created part (without save) into an assembly?
liminma8458
Message 1 of 8
liminma8458
Hi, everyone,
I am creating a part document from a custom part template using such as:
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject, "C:\3D\......\my_std_part.ipt", False)
Before saving it, I want to assemble it into an assembly using (the purpose of this is to preview how this new part fit in the assembly first, then decide keep it or not):
oOcc = ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.Add(full_path_file_name, oPositionMatrix)
Because I do not save it yet, this oPartDoc only has a name such as Part1, Part2 and so on assigned by system, but without a full path name. So is it possible adding this oPartDoc into an assmebly, and save it later?
Thank you very much in advance.
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
Replies (7)
Message 2 of 8
bradeneuropeArthur
First create the part separately.
then add it to your assembly.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
liminma8458
I mean how to use API to do it. Even you do it manually, looks like you need to save the part file first then assemble it.
Limin
Message 4 of 8
bradeneuropeArthur
Public Sub d()
Dim a As Application
Set a = ThisApplication
Dim ba As AssemblyDocument
Set ba = a.ActiveDocument
'Set b = a.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim bp As PartDocument
Set bp = a.Documents.Add(kPartDocumentObject, , True)
Call bp.SaveAs("D:\Test.ipt", False)
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
Dim oMatrix As Matrix
Set oMatrix = oTG.CreateMatrix
Call oMatrix.SetTranslation(oTG.CreateVector(3, 2, 1))
' Add the occurrence.
Dim oOcc As ComponentOccurrence
Set oOcc = oAsmCompDef.Occurrences.Add("D:\Test.ipt", oMatrix)
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
liminma8458
bradeneurope,
Thank you very much for your code. As in your code, we have to "Call bp.SaveAs("D:\Test.ipt", False)" to save bp (PartDocument) to a specific name ("D:\Test.ipt") in disc first, then we can use this name as a handle to assemble it (Set oOcc = oAsmCompDef.Occurrences.Add("D:\Test.ipt", oMatrix)).
But my problem is that I don't know whether this bp (PartDocument) is what I want. I just want to see it in the assembly first, then I can decide to save it later or just skip it
My challenge is whether we can do something to add bp (PartDocument) directly  like:
Set oOcc = oAsmCompDef.Occurrences.Add(bp, oMatrix)
Any way to do it?
Thanks again
Limin
Message 6 of 8
bradeneuropeArthur
Simply delete the file from disc if you do not want to keep it!!!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 8
liminma8458
Bradeneurope:
Thank you for giving me the hint. I got it work the way I want by modifying your code as:
Public Sub d()
'Call bp.SaveAs("D:\Test.ipt", False)
'Set oOcc = oAsmCompDef.Occurrences.Add("D:\Test.ipt", oMatrix)
Set oOcc = oAsmCompDef.Occurrences.AddByComponentDefinition(bp.ComponentDefinition, oMatrix)
ba.Activate
End Sub
Thanks again
Limin
Message 8 of 8
bradeneuropeArthur
Thank you for the Hint!
Added this line of code? ba.Activate
I need to be more careful before I release my ideas and solution.
Good job.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
