iFeature
iFeature
martinhoos
iFeature
martinhoos
Hi all,
i am looking for a solution that checks if a iFeature exists.
If yes, i need a rename of the iFeature.
If no, skip the rule.
Thanks in advance.
Regards Martin
bradeneuropeArthur
Any feature?
Or a specific one?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Public Sub d()
Dim a As Application
Set a = ThisApplication
Dim b As PartDocument
Set b = a.ActiveDocument
Dim c As Features ' ExtrudeFeature
'Set c = b.ComponentDefinition.Features
For Each F In b.ComponentDefinition.Features
If F.Name = "YOUR NAME TO BE FOUND" Then
F.Name = "YOUR NAME TO BE CHANGED INTO"
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
martinhoos
Hello Brandeneurope,
your code runs... ! Thank you.
Regards Martin
bradeneuropeArthur
My pleasure to help you.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
