Inventor Vb.Net "AddIn" - Get Frame Generator Cut Length
isocam
isocam
Can anybody help?
I am trying, using a Vb.Net "AddIn", to  get the lengths of each separate member in a frame, generated using the frame generator tool in Inventor.
Below is my code so far....
Sub GetCutLengths(oDoc)
Dim oAsm As AssemblyDocument
Dim oOcc As ComponentOccurrence
Dim oUM As UnitsOfMeasure
oUM = oDoc.UnitsOfMeasure
For Each oOcc In oAsm.ComponentDefinition.Occurrences.AllLeafOccurrences
oDoc = oOcc.Definition.Document
Dim maxz As Double
Dim minz As Double
Dim height As Double
maxz = oOcc.Definition.rangeBox.MaxPoint.Z
minz = oOcc.Definition.rangeBox.MinPoint.Z
height = maxz - minz
On Error Resume Next
If height <> 0 Then
oDoc.ComponentDefinition.Parameters.UserParameters.Item("G_L").Value = height
SectionType = oDoc.PropertySets.Item("Content Library Component Properties").Item("Family").Value
Select Case SectionType
Case "DIN 59410 (Rectangular)"
SectionType = "RHS"
Case "DIN 59410 (Square)"
SectionType = "SHS"
End Select
Size = oDoc.PropertySets.Item("Design Tracking Properties").Item("Size Designation").Value
Size = Replace(Size, "x", " x ")
Length = Trim(Str(Val(oUM.GetStringFromValue(height, oUM.LengthUnits))))
PartDescription = SectionType + ": " + Size + " x " + Length + " LONG"
Msgbox(PartDescription)
Next
End Sub
I am having issues with the first three lines of code (Highlighted in red).
Does anybody have any idea what is wrong?
Many thanks in advance!
Darren
bradeneuropeArthur
Can you please upload the complete vb.net project here?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
C_Haines_ENG
This works in iLogic. I'm still not sure if you're using VBA or iLogic, but you should be able to convert it.
Sub Main
	Dim oAsm As AssemblyDocument = ThisDoc.Document
	For Each oOcc As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences.AllLeafOccurrences
		If oOcc.ReferencedDocumentDescriptor.ReferencedDocument.DocumentInterests.HasInterest("{AC211AE0-A7A5-4589-916D-81C529DA6D17}") = True _
			And oOcc.Name <> "Frame Reference Model" Then
			Dim Max As Point = oOcc.Definition.RangeBox.MaxPoint
			Dim Min As Point = oOcc.Definition.RangeBox.MinPoint
			Dim oList As New List(Of Double)
			oList.AddRange({Max.X - Min.X, Max.Y - Min.Y, Max.Z - Min.Z })
			MsgBox(oOcc.Name & " = " & oList.Max & "cm")
	Next
End Sub
