Give me the current date and time in a format that can be saved
jake_egley
jake_egley
I want a variable named Time that contains the current date and time in a format that can be saved.
Such that I can use a function like this:
System.IO.File.Copy("C:\filename.xltx", "C:\filename_" & Time & ".xltx")
Thank you
Jake Egley
Inventor 2022
Curtis_Waguespack
Hi @jake_egley ,
Welcome to the forum.
I think something like this should work.
Hope that helps,
Curtis
Dim Time As String = DateTime.Now.ToString("HHmmss")
Logger.Info("Current Time: " & Time)
Dim oDate As String = DateTime.Now.ToString("MMddyyyy")
Logger.Info("Formatted Date: " & oDate)
System.IO.File.Copy("C:\filename.xltx", "C:\filename_" & oDate & "_" & Time & ".xltx")
jake_egley
@Curtis_Waguespack That works, thanks. What is the purpose of the Logger lines?
Jake Egley
Inventor 2022
jake_egley
@Curtis_Waguespack I am now trying to write this into a macro in VBA and it doesn't work, how do you write it in VBA?
Jake Egley
Inventor 2022
Curtis_Waguespack
@jake_egley
I didn't test/run this... but it would be something like this for VBA
Dim Time As String
Set Time = DateTime.Now.ToString("HHmmss")
Dim oDate As String
Set oDate = DateTime.Now.ToString("MMddyyyy")
Call System.IO.File.Copy("C:\filename.xltx", "C:\filename_" & oDate & "_" & Time & ".xltx")
