Replace all occurrences of Machine mark
karthur1
Mentor Mentor
karthur1
When I am updating older drawings, I would like to change the machine marks to the mark for "Material removal required".  That is the one circled below.  With the drawing open, I would like to be able to run an iLogic code to search and replace all occurrences with the newer symbol.  If the current machine mark has optional text (like the one below that says "Min. Cleanup), then that would be transferred over to the new symbol.  Would it be possible to do that?
Curtis_Waguespack
Hi @karthur1 ,
I think this will work for you.
hope that help,
Curtis
Dim oSheet As Sheet = ThisDoc.Document.ActiveSheet
For Each oSymbol As SurfaceTextureSymbol In oSheet.SurfaceTextureSymbols
	If oSymbol.Definition.SurfaceTextureType = SurfaceTextureTypeEnum.kBasicSurfaceType Then
		oSymbol.Definition.SurfaceTextureType = SurfaceTextureTypeEnum.kMaterialRemovalRequiredSurfaceType
Next
karthur1
Perfect!
Thanks for the help.
