Inventor Ribbon Customization
Jason.Rugg
Message 1 of 23
Jason.Rugg
I have developed many external ilogic rules/commands that are fired from customized buttons in the ribbon menu. I need to push these buttons out to all users, to do this I have been exporting out the "Customization Settings" and then manually importing them on all other machines. Is there a way to automate this so I don't have to do this manually on all machines?
Replies (22)
Message 2 of 23
bradeneuropeArthur
what do you understand under Customized buttons?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 23
Jason.Rugg
What do you mean by that question?
Message 4 of 23
bradeneuropeArthur
how did you create your custom buttons in the inventor ribbon.
With:
-Vba or
-Vb.net?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 23
Jason.Rugg
I just use the built in VBA Editor in Inventor.
Message 6 of 23
bradeneuropeArthur
You can run the inventor exe with the xml setting!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 23
Jason.Rugg
Can you elaborate on that? Not sure what you mean by running the the .exe with the .xml.
Message 8 of 23
Jason.Rugg
The following is what I am envisioning but not sure what switch to use for the customization settings.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/simplecontent/content/co...
Message 9 of 23
bradeneuropeArthur
put this in your inventor exe shortcut:
"C:\Program Files\Autodesk\Inventor 20yy\Bin\Inventor.exe" /importcustomizations="C:\Preferences\test.xml"
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 23
Jason.Rugg
I found some switches and tried them but they didn't work, Inventor launched without any errors but the settings were not imported. Here are the two commands I tried:
"C:\Program Files\Autodesk\Inventor 2019\Bin\Inventor.exe" /IMPORTCUSTOMIZATIONS="\\kcidata\cad\cad\Inventor Customizations\2019\Migration Settings\CustomizeUserCommands 10-31-2018.XML
"C:\Program Files\Autodesk\Inventor 2019\Bin\Inventor.exe" /IMPORTRIBBONCUSTOMIZATIONS="\\kcidata\cad\cad\Inventor Customizations\2019\Migration Settings\CustomizeUserCommands 10-31-2018.XML
Message 11 of 23
bradeneuropeArthur
I will test it tomorrow  and will let you know. I am far from my desk right know.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 23
Jason.Rugg
According to the following post for Inventor 2018, the command line switch(s) may not be working. I am using 2019 and they are working, so maybe this is still an issue that is still being investigated.
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Message 13 of 23
DRoam
I'm in the exact same boat, @Jason.Rugg. I want to automate the process of adding VBA macros to the ribbon. There seem to be only two ways of doing this currently, and both of them have their issues.
You can add the command line switch to import customization settings, but that still requires manually setting that up, and even worse, it wipes out any customizations that the user may have done... this is a deal-breaker in my opinion.
The other method is using the methods avaialbe under ThisApplication.UserInterfaceManager (see this thread). However, I've experienced some issues with this. I've read that these changes don't persist from session to session. And I haven't fully tested this because, the last time I tried using this to add Ribbon buttons, my Customizations XML file ended up corrupted I had to reset it.
So I'm with you and would really like to know if someone out there has developed a stable iLogic/VBA solution for automatically adding buttons to the ribbon...
Message 14 of 23
bradeneuropeArthur
The Very best option is to start writing your first add in for this.
All the questions and issues with ilogic are solved then.
I could guide you in the right direction of needed...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 23
Curtis_W
I've got this in place, but it's a bit involved... I'll try to put something together that makes sense.
Message 16 of 23
DRoam
Thanks very much, Curtis, I'd appreciate it.
Perhaps if you try imagining it as a spoon...
Message 17 of 23
DRoam
That's what I would ultimately like to do but I'm not quite ready to go down that hole yet. I don't have any experience with add-ins, and I need to get this deployed soon (and be confident that it will be stable for our many users.). I mostly have the iLogic infrastructure in place, I just need to make it more accessible in a user-friendly way.
Would appreciate any resources you have though, for when I do decide to tackle this.
Message 18 of 23
Curtis_W
This example expects to find 3 external rules called:
  • Spoon Rule
  • Fork Rule
  • Knife Rule
you would change the names in the sub routines to match the name of your rules, and add subs as needed to add more buttons to the ribbon.
This example creates a "My  _____ Tools' Panel on the tools tab of the ribbon for the file type of the active file.
Start the VBA editor
  • Locate the Modules folder in the Application Project and right click on it and choose Insert > Module
  • Rename the Module something like Module_CustomRibbon
  • Paste in this code:
Sub Customize_Ribbon()
    ThisApplication.SilentOperation = True
    'silently create file of type
    'set the custom ribbon panel
    'then close the file
    ' Create a new Assembly document, using the default Assembly template.
    Dim oAssemblyDoc As AssemblyDocument
    Set oAssemblyDoc = ThisApplication.Documents.Add(kAssemblyDocumentObject, _
                ThisApplication.FileManager.GetTemplateFile(kAssemblyDocumentObject), True)
    Call SetRibbon
    oAssemblyDoc.Close
    ' Create a new Drawing document, using the default Drawing template.
    Dim oDrawDoc As DrawingDocument
    sTemplate = "\\SERVER\Departments\CAD\Inventor\Macros\Macro_Template.idw"
    Set oDrawDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, _
                sTemplate, True)
    Call SetRibbon
    oDrawDoc.Close
    ' Create a new part document, using the default part template.
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
                ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject), True)
    Call SetRibbon
    oPartDoc.Close
    ThisApplication.SilentOperation = False
 End Sub
Sub SetRibbon()
    Dim oRibbon  As Inventor.Ribbon
    'determine file type
    If ThisApplication.ActiveDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
        Set oRibbon = ThisApplication.UserInterfaceManager.Ribbons.Item("Assembly")
        oType = "Assembly"
    ElseIf ThisApplication.ActiveDocumentType = DocumentTypeEnum.kPartDocumentObject Then
        Set oRibbon = ThisApplication.UserInterfaceManager.Ribbons.Item("Part")
        oType = "Part"
    ElseIf ThisApplication.ActiveDocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
        Set oRibbon = ThisApplication.UserInterfaceManager.Ribbons.Item("Drawing")
        oType = "Drawing"
    Else
        oType = "Unknown"
    If oType = "Unknown" Then
        Exit Sub
    'Get the "Tools" tabs
    Dim oTab As RibbonTab
    Set oTab = oRibbon.RibbonTabs.Item("id_TabTools")
    oTab.Active = True
    'clean up existing custom panels
    'this prevents errors when panels
    'already exists
    Dim oPanel As RibbonPanel
    For Each oPanel In oTab.RibbonPanels
        If oPanel.DisplayName = "My Assembly Tools" _
        Or oPanel.DisplayName = "My Drawing Tools" _
        Or oPanel.DisplayName = "My Part Tools" Then
            oPanel.Delete 'remove it
    Next
    ' Create a panels
    Dim oPanel_Assem As RibbonPanel
    Set oPanel_Assem = oTab.RibbonPanels.Add("My Assembly Tools", "ToolsTabAssemPanel", "SampleClientId")
    Dim oPanel_Draw As RibbonPanel
    Set oPanel_Draw = oTab.RibbonPanels.Add("My Drawing Tools", "ToolsTabDrawPanel", "SampleClientId")
    Dim oPanel_Part As RibbonPanel
    Set oPanel_Part = oTab.RibbonPanels.Add("My Part Tools", "ToolsTabPartPanel", "SampleClientId-3")
Dim oMacroDef As MacroControlDefinition
If oType = "Assembly" Then
    Set oMacroDef = ThisApplication.CommandManager.ControlDefinitions. _
    AddMacroControlDefinition("Module_iLogicRules.Bend Spoon Rule")
    oPanel_Assem.CommandControls.AddMacro oMacroDef, False
    AddMacroControlDefinition("Module_iLogicRules.Bend Fork Rule")
    AddMacroControlDefinition("Module_iLogicRules.Bend Knife Rule")
ElseIf oType = "Drawing" Then
    'add drawing rules code here
ElseIf oType = "Part" Then
     'add part rules code here
End Sub
  • Again locate the Modules folder in the Application Project and right click on it and choose Insert > Module
  • Rename the Module something like "Module_iLogicRules"
'Module_iLogicRules
'this module allows iLogic rules to be triggered
'from a VBA macro, fired from a ribbon button
Public Sub Spoon_rule()
    'ilogic rule name:
     RuniLogicExt "Bend Spoon Rule"
End Sub
Public Sub Fork_Rule()
    'ilogic rule name:
     RuniLogicExt "Bend Fork Rule"
End Sub
Public Sub Knife_Rule()
    'ilogic rule name:
     RuniLogicExt "Bend Knife Rule"
End Sub
Public Sub RuniLogicExt(ByVal RuleName As String)
   Dim oPath As String
   oPath = "\\server\departments\CAD\Inventor\iLogic\"
   Dim iLogicAuto As Object
   Dim oDoc As Document
   Set oDoc = ThisApplication.ActiveDocument
   If oDoc Is Nothing Then
      MsgBox "Missing Inventor Document"
      Exit Sub
   Set iLogicAuto = GetiLogicAddin(ThisApplication)
   If (iLogicAuto Is Nothing) Then
   MsgBox "iLogicAuto Is Nothing"
   Exit Sub
   iLogicAuto.RunExternalRule oDoc, oPath & RuleName & ".iLogicVb"
End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object
   Set addIns = oApplication.ApplicationAddIns
   Dim addIn As ApplicationAddIn
   On Error GoTo NotFound
   Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
   If (addIn Is Nothing) Then Exit Function
   addIn.Activate
   Set GetiLogicAddin = addIn.Automation
   Exit Function
NotFound:
End Function
Example result for an assembly file
Message 19 of 23
Jason.Rugg
Thanks Curtis, I will also give this a try and see if I can adapt it to my customizations. Can you shoot me a private message when you have a chance?
Message 20 of 23
DRoam
Haha, thanks a ton, Curtis. What, no cutlery icons for the macro buttons? 😉
Question about this... in this blog post: Rename the "User Commands" panel, Mr. Nagy says that "programmatically added UI elements are not persisted. So you would have to run your command that adds the extra ribbon panel each time Inventor starts."
Does it apply to your rule as well? If not, what makes his rule different?
If programmatically-added UI elements ARE persisted, can you tell me how/where they are stored, and is there any way to reset the UI if anything goes wrong?
