Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
iLogic, save all .idw sheets to PDF
vance
Message 1 of 12
vance
I am having trouble updating an ilogic rule that saved IDW files to PDF it worked fine in 2016 but is throwing error messages in 2018.
I have followed the forum answers for fixing the 1 first error but now get a new error.
" unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL)"
The code creates a PDF but it is unreadable by adobe PDF reader??
I have pasted my code below:
SyntaxEditor Code Snippet
 '------start of iLogic-------
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'Define the drawing
Dim oDrawing As DrawingDocument
oDrawing = ThisDoc.Document
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
Dim sSheetName As String
Dim iSheetNumber As Integer
oSetFileName = InputRadioBox("Set the file names as created??", "Yes", "No", True, Title := "SET FILE NAMES")
oRevNo = InputBox("REV-NO."& vbCrLf & _
"IF NONE REQUIRED DELETE ? ", "Set REV NO", "?")
oFolder = oPath & "\PDF"
MessageBox.Show("FILES WILL BE SAVED IN. " & vbCrLf & vbCrLf & oFolder, "Files saved in.")
'step through each drawing sheet
For Each oSheet In oDrawing.Sheets
    'find the seperator in the sheet name:number
    lPos = InStr(oSheet.Name, ":")
    'find the number of characters in the sheet name
    sLen = Len(oSheet.Name)
    'find the sheet name
    sSheetName = Left(oSheet.Name, lPos -1)
    'find the sheet number
    iSheetNumber = Right(oSheet.Name, sLen -lPos)
'set PDF Options
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange
oOptions.Value("Custom_Begin_Sheet") = iPageNumber
oOptions.Value("Custom_End_Sheet") = iPageNumber
'get PDF target folder path
'MessageBox.Show(oFolder, "Title")
        'Check for the PDF folder and create it if it does not exist
        If Not System.IO.Directory.Exists(oFolder) Then
            System.IO.Directory.CreateDirectory(oFolder)
        If oSetFileName = True Then
            oFilename = InputBox("Is this the file name you want??", "Title", sSheetName  & "-" &  oRevNo )
        ElseIf oSetFileName = False Then
            oFilename = sSheetName  & iSheetNumber & "-" &  oRevNo
'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFilename & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
FilePath = oFolder
'MessageBox.Show(oFilename, "Title")
Next
'------end of iLogic-------
Any help would be greatly appreciated....
Replies (11)
Message 2 of 12
rhasell
Hi
I have not had time to debug your code, but in testing I found that it is linked to the "Sheet Range" The original code was generating zero byte files, that why you could not read them.
Anyway attached is my testing, perhaps you can take it from there?
Reg
2026.3
Message 3 of 12
vance
Thank you for your response.
Unfortunately I am still unable to make the code work, any further assistance would be appreciated.
Message 4 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @vance,
Try the following iLogic code which exports all sheets to single pdf from a .Idw file.
Sub Main()
    ' Get the PDF translator Add-In.
    Dim PDFAddIn As TranslatorAddIn
    PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document
    Dim oContext As TranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
    ' Check whether the translator has 'SaveCopyAs' options
    If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        ' Options for drawings...
        oOptions.Value("Remove_Line_Weights") = 0
        oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
        'oOptions.Value("Custom_Begin_Sheet") = 2
        'oOptions.Value("Custom_End_Sheet") = 4
    'Set the destination file name
    oDataMedium.FileName = "c:\temp\test.pdf"
    'Publish document.
    Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
Please feel free to contact if there is any doubt.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 5 of 12
vance
Thank you yes that worked.
Message 6 of 12
FProcp
Thanks very much for this ilogic code Chandra.
I am trying to get it to save to a folder named "pdf" in one directory up from where I am working.
I have placed in some code to establish the "pdf" target folder and it uses the variable oFolder
But I cannot seem to get it to work?
Sub Main()
    oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF"
    oRevNum = iProperties.Value("Project", "Revision Number")
    oDataMedium.FileName = "x:\design\pdf\" & oFileName & " Rev" & oRevNum & ".pdf"
    'oDataMedium.FileName = oFolder & "\" & oFileName & " Rev" & oRevNum & ".pdf
    'Publish document.
End Sub
Franco
GMT +08:00
Message 7 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @FProcp,
I don't see any problem in the code. Try the following code which is cleaned.
Sub Main()
    'Publish document.
End Sub
Please feel free to contact if there is any queries,
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 12
FProcp
Thank you so much Chandra but I do not want it to save to "x:\design\pdf\"
Please remove that line and un-comment the next line where it will save to "oFolder"
"oFolder" will be a folder determined as one up from where my .idw is.
Franco
GMT +08:00
Message 9 of 12
FProcp
This seems to work?
Sub Main()
    'oDataMedium.FileName = "x:\design\pdf\" & oFileName & " Rev" & oRevNum & ".pdf"
oDataMedium.FileName = oFolder & "\" & oFileName & _
    'Publish document.
End Sub
Franco
GMT +08:00
Message 10 of 12
FProcp
The above will not work if the "PDF" folder does not already exist.
The following code has been modified to create the "PDF" folder if it does not exist.
This version is better.
Sub Main()
    'Publish document.
End Sub
Franco
GMT +08:00
Message 11 of 12
Hi All
A lot of these codes are quite long to just save a PDF.
This is mine:
'Obtain info
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
'Options
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Vector_Resolution") = 800
'File Path
oPath=ThisDoc.PathAndFileName(False)
oRev = iProperties.Value("Project", "Revision Number")
oDataMedium.FileName = oPath & " Rev" & oRev & ".pdf"
'Publish document
Message 12 of 12
Good day to all!
Is it possible for this code to run one time for all of my open idw files?
