Select Case, can I add two parameters here, convert string problems
tracey
tracey
Hi Guys, still trying to fix the problem.
Door_Lower and Door_Upper have derived values of KK and L.  Trying to get the code to choose a Door (Case1, etc)
Any thoughts
Dim expression As String = (Door_Lower) AndAlso (Door_Upper)
Select Case (Door_Lower) AndAlso (Door_Upper)
    Case 1 "AA","BB","CC","DD","EE","FF","II","JJ","KK","LL","OO","PP","QQ","GG","HH","MM","NN"
        MsgBox("Door E6 Both")
    Case 2 "GG","HH","MM","NN","G","H","M","N"
        MsgBox("Door E2E4 Both")
    Case 4 "A","B","C","D","E","F","I","J","K","L","O","P","Q","G","H","M","N"
        MsgBox("Door E6 Lower.")
    Case 4 "GG","HH","MM","NN","A","B","C","D","E","F","I","J","K","L","O","P","Q","G","H","M","N"
        MsgBox("Door E6 Upper.")
    Case Else
        MsgBox("No match found.")
End Select
bretrick30
I know I'm kind of late to the party, but you are still having issues with this,  remove the number after the cases:
Case "AA","BB","CC","DD","EE","FF","II","JJ","KK","LL","OO","PP","QQ","GG","HH","MM","NN"
