Change Design View Representation of Sub-Assembly in Assembly
insomnix
insomnix
In the main assembly, there are some sub-assemblies with a design view rep. I would like to change the design view using iLogic. The below code will find my part, but instead of changing the design view, it errors. The "tan" view does exist in the sub assembly, so I'm not sure why it would error.
	Dim oDoc As AssemblyDocument = ThisDoc.Document
	Dim oCompDef As Inventor.ComponentDefinition = oDoc.ComponentDefinition
	Dim oCompOcc As Inventor.ComponentOccurrence
	For Each oCompOcc In oCompDef.Occurrences
		If oCompOcc.Name = "std drwr:1" Then
			Try
				oCompOcc.RepresentationsManager.DesignViewRepresentations.Item("tan").Activate
			Catch
				MessageBox.Show("This viewrep does not exist", "Error")
			End Try
	Next
It would also be nice to change the view without having to cycle trough every part in the main assembly. I haven't found a way to get a part by name and perform functions on that part unless it was in the limited list on the Component Functions Reference page.
YuhanZhang
Try if below updated code works or not:
            Try
                oCompOcc.SetDesignViewRepresentation("tan",,True)
            Catch
            End Try
    Next
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
insomnix
Thank you, worked great.
