Driving iLogic Assembly from Drawing Sheet using iLogic and Form
Message 1 of 8
Hi Everyone.
I am new to iLogic coding and have developed iLogic assembly with iLogic parts that are driven from a multi value parameter to select a build based on selection.
It works perfectly on part and assembly level.
How can I drive the assembly model from the drawing sheet work space?
The model is for a ladder assembly with varying lengths as per selection.
The selection of the model instance would be used to drive a parts list as well.
Regards
Kavir
Mechanical Engineer
South Africa
Replies (7)
Message 2 of 8
Thomas_Savage
Hello @Anonymous
Could you attach your Inventor files please?
Thomas.
Thomas Savage
Design Engineer
Message 3 of 8
Hello @Thomas_Savage
Thank you for the interest in my query.
Please see attached part and assembly files.
The assembly and part files can be driven from the "form"
I wish to be able to rive them from a drawing sheet (.idw) environment using a form
Message 4 of 8
Thomas_Savage
Youre Welcome @Anonymous
I will look at this and get beck to you.
Thomas.
Thomas Savage
Design Engineer
Message 5 of 8
Thomas_Savage
Hello @kavir
I have not got access to 2019 at the moment.
So i have created a .IPT, .IAM and .IDW.
I have shown changing the sizes of my block from the Drawing sheet. which then changing the sizes in the .IAM and .IPT. Plus shown the iLogic codes i have used.
Hope this is what you wanted to achieve? And helps you achieve what you want?
If you need any more help, i will be happy to help you.
Thomas.
Thomas Savage
Design Engineer
Message 6 of 8
Hi @Thomas_Savage
Thank you for the swift response. That looks to be the outcome I wish to achieve, but i am no seeing success as yet.
I am currently trying to implement your suggested approach.
I seem to be getting an error
"Object reference not set to an instance of an object"
I will keep working on it and if I have success then I will update you.
Regards
Kavir
Message 7 of 8
Hi @Thomas_Savage
I think I got it to work. I will play around with it a bit more and provide feedback on the results
Thank you.
Regards
Kavir
Message 8 of 8
Thomas_Savage
Hello @Anonymous
Yes provide feedback please.
When i can access 2019, i will download your file and create a code that will work on your file.
Thomas.
Thomas Savage
Design Engineer
