Message 1 of 8
10:07 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Everyone.
I am new to iLogic coding and have developed iLogic assembly with iLogic parts that are driven from a multi value parameter to select a build based on selection.
It works perfectly on part and assembly level.
How can I drive the assembly model from the drawing sheet work space?
The model is for a ladder assembly with varying lengths as per selection.
The selection of the model instance would be used to drive a parts list as well.
Regards
Kavir
Mechanical Engineer
South Africa
