inventor not responding
Message 1 of 34
hi i have a problem when i try to open a file the program not responding.
i have windows 7 64 bits and i install the updates but don't work.
Replies (33)
Message 21 of 34
its a little better but is slow to open files
Message 22 of 34
its little better but is slow to open files
Message 23 of 34
bradeneuropeArthur
did you install 2018.2.3!!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 24 of 34
yes i do
Message 25 of 34
bradeneuropeArthur
Could you please make a screenshot of the "About inventor" Dialog. Found in the Right Top Corner next to the Help .....?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 26 of 34
Message 27 of 34
bradeneuropeArthur
Seems to be correct.
This is not the problem then.
Are you using AutoCAD also?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 28 of 34
no, only inventor
Message 29 of 34
bradeneuropeArthur
Are using Vba?
Or I logic?
Are you using many links to servers like:
  • Design data
  • libraries
  • template
  • etc
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 30 of 34
only templates.
Message 31 of 34
bradeneuropeArthur
could you upload your project *ipj file?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 32 of 34
i need this formats because other peoples use the drawing too
Message 33 of 34
bradeneuropeArthur
could you upload/share/provide/send your project *ipj file?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 34 of 34
im use the same project in others pc's and works fine.
