how to add the user parameter to Sketch using vb.net
Hi all
I am karthick
I am created user parameter in inventor using vb.net.
I want add that parameters newly created sketch (line or circle)
Sketch parameters not visualizing in fx table
REFER BELOW IMAGE
how can i trier this using vb.net any code available for this list parameter
regards
Karthick
No one this there for above condition
dgreatice
Can you share you first VBa Code.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Sub extru()
Dim aa, bb, cc, dd, ee, ff, gg, hh As Integer
Dim i As Integer = 1
Dim ii As Integer
oTG = inventorApp.TransientGeometry
partDoc = inventorApp.ActiveDocument
oPartCompDef = inventorApp.ActiveDocument.ComponentDefinition
oPositionMatrix = inventorApp.TransientGeometry.CreateMatrix
DataGridView1.DataSource = DtSet.Tables(0)
Dim oUserParam As UserParameter
oUserParam = oPartCompDef.Parameters.UserParameters.AddByValue("length", 6, UnitsTypeEnum.kCentimeterLengthUnits)
For Each iDataRow As DataRow In DtSet.Tables(0).Rows
aa = iDataRow.Item(4)
bb = iDataRow.Item(5)
ff = iDataRow.Item(6)
oSketch = partDoc.ComponentDefinition.Sketches.Add(partDoc.ComponentDefinition.WorkPlanes.Item(ff))
oSkPnts = oSketch.SketchPoints
oCircule = oSketch.SketchCircles
Call oSkPnts.Add(oTG.CreatePoint2d(aa, bb))
On Error Resume Next
cc = iDataRow.Item(1)
oCircule = oCircule.AddByCenterRadius(oSkPnts(1), cc)
dd = iDataRow.Item(2)
dd = cc - dd
oCircule = oCircule.AddByCenterRadius(oSkPnts(1), dd)
ee = iDataRow.Item(3)
' hear i need to add the parameter value for 2D skitch
oProfile = oSketch.Profiles.AddForSolid
oSketch.Edit()
oSketch.DimensionConstraints.Parameter(oUserParam)
oExtrude = oPartCompDef.Features.ExtrudeFeatures.AddByDistanceExtent(oProfile, ee, PartFeatureExtentDirectionEnum.kPositiveExtentDirection, PartFeatureOperationEnum.kJoinOperation)
On Error GoTo 0
Next
End Sub
