Inventor macro to create another macro
Hello fellows,
I am trying to create an Inventor macro to create another "hello" macro.
That means, first check if the "hello" macro exists and if not, create it with a MsgBox("hello world")
Does anyone know how to do this?
Thanks, Robert
AlexFielder
I would recommend you search these forums for the following:
ilogicvb.automation
This is how you gain access to the iLogic Automation Object which will allow you to add an iLogic rule from a separate iLogic rule.
bradeneuropeArthur
I have this example.
I could send you this earliest on Monday...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Earlier then expected:
Public Sub SheetMetalAutoMacroAdd()
    Dim VBProj As VBIDE.VBProject
    Dim VBComp As VBIDE.VBComponent
    Set VBProj = ThisApplication.ActiveDocument.VBAProject.VBProject '.VBE.VBProjects
    On Error Resume Next
    If Not VBProj.VBComponents.Item(3).Name = "X" Then
        Set VBComp = VBProj.VBComponents.Add(vbext_ct_StdModule)
        VBComp.Name = "X"
    If Not VBProj.VBComponents.Item(4).Name = "Y" Then
        VBComp.Name = "Y"
        For Each oVBProject In ThisApplication.VBE.VBProjects
        Debug.Print oVBProject.Name
        If oVBProject.Name = "DocumentProject" Then
           For Each oVBComponent In oVBProject.VBComponents
                If oVBComponent.Name = "X" Then
                    MsgBox oVBComponent.Name
                    oVBComponent.CodeModule.DeleteLines 1, oVBComponent.CodeModule.CountOfLines
                    oVBComponent.CodeModule.AddFromFile ("C:\_ExportedModules\X.txt")
                If oVBComponent.Name = "Y" Then
                    oVBComponent.CodeModule.AddFromFile ("C:\_ExportedModules\Y.txt")
            Next
           Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
