How to add the total QTY to the parts list?
Message 1 of 17
how can I add the sum of Item QTY to the parts list.
Replies (16)
Message 2 of 17
Cadmanto
iLogic is the only way I can think of to accomplish this.  See if the attached link offers you some solution.
http://adndevblog.typepad.com/manufacturing/2013/12/bom-item-total-quantity-by-sub-assemby.html
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 17
thank you for your answer,
I tried to solve it with the code but i have this error:
Do you have any idea about it?
Message 4 of 17
Cadmanto
I don't, sorry.  I am not an iLogic guru.  I can change and dabble with extremely minor lines, but not full blown code. Smiley Sad
I know there are others on the forum that get probably get this to work.
Best Regards,
Scott McFadden
Message 5 of 17
MechMachineMan
Try this:
Sub Main()
	oQTYCol = 2
	Dim oDoc As Document
	oDoc = ThisDoc.Document
	oSheet = oDoc.ActiveSheet
oTotal = 0
For Each oPL In oSheet.PartsLists For Each oRow In oPL.PartsListRows oTotal = CInt(oRow.Item(oQTYCol).Value) + oTotal Next oNewRow = oPL.PartsListRows.Add(0) oNewRow.Item(oQTYCol).Value = oTotal oNewRow.Item(oQTYCol-1).Value = "SUM" Next End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 6 of 17
Thank you for the code
It wokrs but the problem is that it counts all parts in the assembly, even the invisible parts.
Message 7 of 17
Thomas_Savage
Hello @kamel9HGBU
I have a way to add up the Total QTY without iLogic.
I have attached a screencast so you can see how.
In the screencast you can see that i have wrote Total QTY in Category in my iProperties.
You need to do this for every part you want to be counted in the Total QTY. So you can pick which ones you want in the Total QTY.
Hope this helps?
Thomas.
Thomas Savage
Design Engineer
Message 8 of 17
To me it looks like your 1,2,3 line is the sum of the rows above. You don't have 6 parts, you only have 3, no?
Message 9 of 17
Thomas_Savage
Hello @Anonymous
I don't understand what you mean?
I do not have 6 parts, or 3. I have 5. So that is 5 Solids in my part. I have attached a screenshot below to show i have 5 Solids in in my assembly.
So in the parts list it adds all the Solids that i type Total QTY in Category, which gives to give a Total QTY.
Thomas.
Thomas Savage
Design Engineer
Message 10 of 17
I was refereing to the OP, sorry
Message 11 of 17
Thomas_Savage
Sorry @Anonymous
It doesn't say who you are replying to anymore
Thomas.
Thomas Savage
Design Engineer
Message 12 of 17
OP Opening Post
Message 13 of 17
MechMachineMan
A very simple "If" statement fixes that.
Sub Main()
	oQTYCol = 2
        oTotal = 0
If oRow.Visible = True oTotal = CInt(oRow.Item(oQTYCol).Value) + oTotal
End if Next oNewRow = oPL.PartsListRows.Add(0) oNewRow.Item(oQTYCol).Value = oTotal oNewRow.Item(oQTYCol-1).Value = "SUM" Next End Sub
Justin K
Message 14 of 17
Thank you for your code
It wokrs but when I press on "Save" it adds the "SUM". and if I press one more time it adds "SUM+ old SUM"
Message 15 of 17
MechMachineMan
So only hit save once then...
or use the further updated version.
Sub Main()
	oQTYCol = 2
        oTotal = 0
If oRow.Item(oQtyCol -1).Value = "SUM"
'Do nothing
Else oTotal = CInt(oRow.Item(oQTYCol).Value) + oTotal
End if End if Next
If oPL.PartsListRows.Item(oPL.PartsListRows.Count).Item(oQtyCol -1).Value = "SUM"
oPL.PartsListRows.Item(oPL.PartsListRows.Count).Item(oQtyCol).Value = oTotal
Else
End if
Next
End Sub
Justin K
Message 16 of 17
@MechMachineMan
thank you very much for the code. It works very good but if i use the filter then it does not work.
Message 17 of 17
MechMachineMan
@Anonymous
 The code fails because there is a limitation through the API of not being able to add a partslistrow to a filtered partslist, but you can through the UI* (*Note for @JaneFan or @chandra.shekar.g)
However, you also need to make sure the SUM row is not filtered off, so that it will appear visible on your filtered partslist... More specifically, it's because the FILTER applies to all rows.... by using the filter "BALLOONED ITEMS" and not having the "SUM" row ballooned, it will not be excluded from the filter.
Therefore, the workaround/solution is to balloon the "SUM" row, and to add the sum row before filtering. To do this:
1. Disable the filter on the PartList then
2.  Run the rule
3. Attach a balloon to any object. (this will be a dummy balloon for the SUM row) Then use attach balloon from list, and attach the "SUM" row. Then remove the balloon number that doesn't correspond with the sum row from that same balloon pair. Then move the "SUM" balloon off page.
4. Apply your filter to the partslist.
5. Run the rule again.
Justin K
