Inventor Apprentice Server - Open dwg Catastrophic failure
5107839414
Message 1 of 8
5107839414
I'm trying to open Inventor DWG with apprentice server but it always throws "Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))".
I'm using Inventor 2022 with same Apprentice version.
The exception is thrown on the following line:
Inventor.ApprenticeServerDrawingDocument dwgDoc = apprentice.Open(dwgPath) as Inventor.ApprenticeServerDrawingDocument;
I can open .ipt, .iam, .idw files but not Inventor .dwg files.
I tried different Inventor .dwg files but none of them worked.
Any ideas why?
Replies (7)
Message 2 of 8
bradeneuropeArthur
Have you installed more versions of inventor?
What if you convert the dwg to idw and than open it with apprentice. Does that work.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
5107839414
If I convert Inventor .dwg to .idw then I can open file in apprentice.
I had multiple versions of Inventor.
I removed 2021 version, restarted computer but the issue still remains.
Message 4 of 8
bradeneuropeArthur
does design assistent work?
Have you also Autocad installed?
Have you set to default use Autocad to open dgw files?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
5107839414
Design Assistant works.
I have Autocad installed.
I tried both Autocad and Inventor as default program for opening .dwg files but apprentice still throws the same exception.
Message 6 of 8
bradeneuropeArthur
can you check the file association for the dwg file?
https://www.digitaltrends.com/computing/how-to-change-file-associations/
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 8
5107839414
.dwg files are associated with Inventor right now.
I also tried to associate them with Autocad, but I still had the same issue.
Message 8 of 8
5107839414
This is my Exception stackTrace:
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.ApprenticeServer.Open(String FullDocumentName)
at InventorProductionExporter.Util.ReadDimensions(Database db) in D:\Dropbox\Developing\InventorProductionExporter\Util.cs:line 31
at InventorProductionExporter.MyCommands.InventorImportNumber() in D:\Dropbox\Developing\InventorProductionExporter\myCommands.cs:line 62
