Retrieve view reps used in idw view
PJKeeffe
PJKeeffe
Is it possible to retrieve the View representations( View,Position & LOD) used as a parameter/text and print  on idw?
CattabianiI
To retrieve that data use the properties from the DrawingView class:
ActivePositionalRepresentation
ActivePresentationView
ActiveLevelOfDetailRepresentation / ActiveModelState
If you want to add them in the drawing you can create general notes after reading that values, check this post and look at the sample: https://forums.autodesk.com/t5/inventor-forum/create-text-box-in-drawing-using-ilogic/m-p/5094780#M5...
PJKeeffe
Thanks-making progress- can retrieve View name, View Position & View LOD but not the View Representation?
Any reason why?
Code to date
Dim oView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select View")
If oView Is Nothing Then Exit Sub
bView = oView.Name
Dim oModelDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oViewRep As String
oViewRep = oView.ActivePresentationView
Dim oViewPos As String
oviewPos = oView.ActivePositionalRepresentation
Dim oViewLOD As String
oViewLOD = oView.ActiveLevelOfDetailRepresentation
MessageBox.Show(bView, "View Name")
MessageBox.Show(oViewRep, "View Details")
MessageBox.Show(oViewPos, "View Position")
MessageBox.Show(oViewLOD, "View LOD")
Thanks in advance
PJ
A.Acheson
You had the incorrect property active this line should be as below.
oViewRep = oView.ActiveDesignViewRepresentation
For some reason this is missing in the online documentation DrawingView @CattabianiI  had kindly posted. You can find this in the drop down in the editor or in the built in API help.
Regards
Alan
PJKeeffe
Thanks- added the line of code via copy/paste (Can't get the dropdown menu to appear) but still no result in message box. Also trying to find a snippet or command that returns the co-ordinates of the selected view to enable printing of the view data in relation to the view position- can you help thanks
JelteDeJong
Check this forum topic "DrawingView->ActivePresentationView never returns value". It seems to be a bug.
Jelte de Jong
Blog: hjalte.nl - github.com
A.Acheson
Is the view set to associative in the drawing? If not the view is a snapshot of the model design view and not linked. I would place in an error catch statement to say not associative if returned blank as this is an important part of updating the views.
Here is a quick one to get the position and here is how to move a label in relation to the view.
Regards
Alan
