Inventor Add in - reference active document in form button
Message 1 of 8
I've created an add-in using Inventor 2017 addin template with a basic form. The addin loads fine and I'm getting the form to appear. I'm going to have various buttons on the form that each add a custom iProperty. How do I declare the active document and custom prop set globally to use in each buttons sub.
I thought this would work but it not...
Imports Inventor
Public Class Form1
Dim oDoc As Document = g_inventorApplication.ActiveDocument
Dim oCustomPropertySet As PropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
Dim prop As Inventor.Property
Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
 Try
prop = oCustomPropertySet.Item("SAW")
Catch
oCustomPropertySet.Add("5", "SAW")
End Try
End Sub
Private Sub Button3_Click(sender As Object, e As EventArgs) Handles Button3.Click
Try
prop = oCustomPropertySet.Item("PUNCH")
Catch
oCustomPropertySet.Add("10", "PUNCH")
End Try
End Sub
End Class
Replies (7)
Message 2 of 8
bradeneuropeArthur
You need to give the inventorapplication of the add in to the form. Do this at new form and declare g_inventorApplication as inventor.application.
Hope this helps.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
Could you give an example please? I'm struggling to understand where to do this
Is it here?
Public Class StandardAddInServer
Implements Inventor.ApplicationAddInServer
Private WithEvents m_uiEvents As UserInterfaceEvents
Private WithEvents m_sampleButton As ButtonDefinition
Dim MyForm As New Form1
Message 4 of 8
bradeneuropeArthur
Take a look.
Hope this explains.
Your form needs to know what the application is so you need to provide it from the add-in.
You understand now?
' this should be added to your add in:
Private _Form1 as Form1
'and this too with the m_inventorApplication as inventor app from the add in
_Form1 = New Form1(m_inventorApplication)
'this should be added to your form:
Public Class Form1
    Public m_InventorApplication As Inventor.Application
Public Sub New(InventorApp As Inventor.Application)
        ' This call is required by the designer.
        InitializeComponent()
        ' Add any initialization after the InitializeComponent() call.
        m_InventorApplication = InventorApp
    End Sub
end class
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
Sorry I've tried a few things but still not getting it. Could you have a look at my two scripts attached, I've stripped them back to what I had originally.
Message 6 of 8
bradeneuropeArthur
Replace this:
Namespace AddOperations
    <ProgIdAttribute("AddOperations.StandardAddInServer"), _
    GuidAttribute("4273d4c1-ecdc-48da-a321-1e3e730949e7")> _
        Dim MyForm As  Form1
#Region "ApplicationAddInServer Members"
        ' This method is called by Inventor when it loads the AddIn. The AddInSiteObject provides access
        ' to the Inventor Application object. The FirstTime flag indicates if the AddIn is loaded for
        ' the first time. However, with the introduction of the ribbon this argument is always true.
        Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
            ' Initialize AddIn members.
            g_inventorApplication = addInSiteObject.Application
            ' Connect to the user-interface events to handle a ribbon reset.
            m_uiEvents = g_inventorApplication.UserInterfaceManager.UserInterfaceEvents
		Dim MyForm As  Form1(g_inventorApplication)
end sub
Private Sub m_sampleButton_OnExecute(Context As NameValueMap) Handles m_sampleButton.OnExecute            'MsgBox("Button was clicked.")            MyForm.ShowDialog()                   End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 8
bradeneuropeArthur
sorry button coding was not visible I see.
            MyForm.ShowDialog()
        End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 8
bradeneuropeArthur
and in the form with this:
Imports Inventor
Imports System.Windows.Forms
Public g_InventorApplication As Inventor.Application
Public Class Form1
Public Sub New(H_inventorApplication as inventor.application)
G_inventorApplication =H_inventorApplication
End Sub
    Dim newpoint As New System.Drawing.Point
    Dim x, y As Integer
    Private Sub Panel1_MouseDown(sender As Object, e As Windows.Forms.MouseEventArgs) Handles Panel1.MouseDown
        x = MousePosition.X - Me.Location.X
        y = MousePosition.Y - Me.Location.Y
    End Sub
    Private Sub Panel1_MouseMove(sender As Object, e As Windows.Forms.MouseEventArgs) Handles Panel1.MouseMove
        If e.Button = Windows.Forms.MouseButtons.Left Then
            newpoint = MousePosition
            newpoint.X -= (x)
            newpoint.Y -= (y)
            Me.Location = newpoint
        End If
    End Sub
    Private Sub CloseButton_Click(sender As Object, e As EventArgs) Handles CloseButton.Click
        Close()
    End Sub
    Private Sub Add_BOND_Click(sender As Object, e As EventArgs) Handles Add_BOND.Click
        Dim oDoc As Document = g_inventorApplication.ActiveEditDocument
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
