iLogic checkbox in global form
b.graaf
b.graaf
I am busy making a global form. In this form several values can be entered. After clicking "OK" an external rule will be executed.
Is it possible to add a checkbox in this global form? This checkbox will influence the iLogic rule which is started after clicking "OK".
Normally, with a local form, I will add a true/false parameter to the file which contains the form and the rule.
But with a global form and external rule I actually would like to solve it without extra parameters within the file.
Is this possible?
Maybe a same kind of question, but is it possbile to use some kind of global variables or temporarily variables in a form, which will be used in the rule after closing the form?
Rob67ert
For that global variable, why not use a part file with a derive?
In the file you derive from you can then select only the parameters.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
b.graaf
Hello Robert,
Tnx for your reply,
Actually I would like to use no file at all to store these needed variables!
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @b.graaf,
Hoping that following article would help. In this article, MessageBox can be used for YES/NO as input.
http://inventortrenches.blogspot.in/2011/03/using-yes-no-message-box-in-your-ilogic.html.
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
