Inventor 2017 R2 API
GeorgK
Advisor Advisor
GeorgK
Hello together,
is there an overview of all new features of the API with samples?
Georg
ekinsb
The best overview that exists for what's new in the API for Inventor 2017 is the "What's New in the Inventor 2017 API" topic in the API help.  It has an overview list of the bigger additions and then has a detailed list of every change.  If you click on the "Sample Programs" folder in the table of contents it will display a page that lists every sample and new samples for that release will have a red "New" beside them.  There aren't too many new samples in this release but there are a few.
Brian Ekins
Mod the Machine blog
MechMachineMan
Is there any place to view this outside of the file downloaded with the 2017 version? I really wanna get a head start on planning my macros.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
ekinsb
I've uploaded the help chm file and you can download it here: https://autodesk.box.com/s/r8rauy3ybgjjj52m1arj9y2rw3hl120g
Brian Ekins
GeorgK
Hello Brian,
it would be great to continue this work:
https://github.com/ADN-DevTech/Inventor-Training-Material
Georg
