custom property to MLeader Text
Alexrose1942
Alexrose1942
i want to add a custom property that work like an "if" function which will be used for piping label
example : if pipe diameter=273.1 then mleader will show Ø10'' as a label.
there will be different pipe sizes.
im a newbie so a simple example will be great. ill try to add all diameters and post it back here so others can use.
I hope this helps:
SyntaxEditor Code Snippet
If Split(Spec, " ")(0) = "TR" Then
    iProperties.Value("Custom", "Description") = "=<PipeOD> x <PipeOD> x <PipeLength1> LG. HEADER (GRAIN #4, 7#)"
Else
    iProperties.Value("Custom", "Description") = "=PIPE <PipeSize> NPS x <PipeTHK> WALL x <PipeLength1> LG. (GRAIN #4, 7#)"
Here is the part file with code in it. I would suggest making it a content center part.
Alexrose1942
I'm using pipes in Tube and Pipe Environment, its should be something more simple than this.
 if the outer diameter of pipe equal 168.3(mm) then the custom property can show Ø6'' with a multileader.
