insert a block from sketch symbols
Miguel.CarvajalS34Q6
Hello boys,
I need to insert a block that is found in the sketch symbols, but I want the block to be inserted automatically when inserting the part in the drawing sheet, for example: if the variable "roughness" = N7, the block that is inserted in the drawing is inserted. indicates N7 surface finish.
taking into account that the coordinate where the block is inserted must change according to the size of the active sheet
thank you for your attention and help
bradeneuropeArthur
Can you share the dwg with the different drawingsymbols?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
all the blocks are in the sketch symbols folder in the drawing module
These are the blocks I am referring to.
