Pretty sure you have to re-add the folders.
Something like below should get you started.
Sub AddFolders()
Dim oPane As BrowserPane
Dim oNode As BrowserNode
Dim oDwgName As BrowserNode
Dim oDwgRes As BrowserNode
Dim oSktch As BrowserNode
Dim oFolder As BrowserFolder
Dim oOccurrenceNodes1 As ObjectCollection
Dim oOccurrenceNodes2 As ObjectCollection
Dim oOccurrenceNodes3 As ObjectCollection
oOccurrenceNodes1 = ThisApplication.TransientObjects.CreateObjectCollection
oOccurrenceNodes2 = ThisApplication.TransientObjects.CreateObjectCollection
oOccurrenceNodes3 = ThisApplication.TransientObjects.CreateObjectCollection
oPane = ThisApplication.ActiveDocument.BrowserPanes("Model")
oDwgName = oPane.TopNode 'Is the WO# and sheet name
oDwgRes = oDwgName.BrowserNodes.Item("Drawing Resources")
oSktch = oDwgRes.BrowserNodes.Item(4)
For Each oFolder In oSktch.BrowserFolders
oFolder.Delete
Next
For Each oNode In oSktch.BrowserNodes
oStr1 = Right(oNode.FullPath, Len(oNode.FullPath) - InStrRev(oNode.FullPath, ":", -1))
If oStr1 = "Assembly/Weldment Label" Or _
oStr1 = "Part Label" Or _
oStr1 = "Section/Detail Label" Or _
oStr1 = "Flat Plate Layout Label"
oOccurrenceNodes1.Add(oNode)
If oStr1 = "Detail Callout" Or _
oStr1 = "Section Symbol" Or _
oStr1 = "Orientation"
oOccurrenceNodes2.Add(oNode)
If oStr1 = "Assembly Weight" Or oStr1 = "Reference Drawing"
oOccurrenceNodes3.Add(oNode)
Next
oPane.AddBrowserFolder("Title Block Symbols", oOccurrenceNodes3)
oPane.AddBrowserFolder("Symbols", oOccurrenceNodes2)
oPane.AddBrowserFolder("Labels", oOccurrenceNodes1)
oSktch.DoSelect
Dim oCommandMgr As CommandManager
oCommandMgr = ThisApplication.CommandManager
Dim oControlDef1 As ControlDefinition
oControlDef1 = oCommandMgr.ControlDefinitions.Item("DrawingResourceSort")
oControlDef1.Execute
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
