Regenerate part rule from assembly
Hello, all.
I have run into a slight problem. I have an assembly with many parts in it. I have a rule called "Gage" in each and every part, which controls a parameter called "Gage" for each part itself. For some reason or another my parameter on some parts is not recognized as being driven by the rule "Gage." If I run the rule Gage then my parameter will not update. However, if I right click and click regenerate then my parameter will update and then it will recognize the parameter as being driven by the rule. I want to write a rule for my assembly that will run through each part and regenerate the rule called "Gage."
Any help is appreciated. Thank you, all.
I have this rule here
Sub Main()
question = MessageBox.Show("Click OK to run the rule Gage in each part of the assembly.", "Run Rule",MessageBoxButtons.OKCancel)
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Call Iterate(oAsmDoc.ComponentDefinition.Occurrences, 1)
End Sub
Private Sub Iterate(Occurrences As ComponentOccurrences, Level As Integer)
'Iterate through Assembly
Dim oOcc As ComponentOccurrence
For Each oOcc In Occurrences
'Find Parts in Assembly
Dim SheetMetalAssembly As String
SheetMetalAssembly = oOcc.Name
Try
'Write iProps to Parts
iLogicVb.RunRule("Gage")
Catch
'MsgBox("Message!")
iLogicVb.UpdateWhenDone = True
End Try
'Run through the sub assemblies
If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
Call Iterate(oOcc.SubOccurrences, Level + 1)
Next
MessageBox.Show ("You have successfully updated iProperties for each of the following parts:" , "Success!")
End Sub
 That I took from another rule and just reworded it, so that it would run the rules "Gage." Nevertheless, I would still like to have a rule that will regenerate the rules instead of just run the rules.
