Get size and position of windows from open parts / assemblies
GeorgK
Advisor Advisor
GeorgK
Hello together,
is there a way to store the position, zoom and size of all open windows?
Thank you
Georg
CCarreiras
HI!
Automatically no, there's no tool to do all that all at once, but...
To have the same zoom, you can create Representations Views with a defined position and Zoom.
To Have all the windows with the same size, go to View panel and select Tile All, or TIle Horizontal/Vertical
CCarreiras
wayne.brill
Hi Georg,
You can get the size and location of windows using the Views of the Application:
Public Sub Views_Test()
    Dim oViews As Views
    Set oViews = ThisApplication.Views
    Dim oView As View
    For Each oView In oViews
        Debug.Print oView.Caption
        Dim Top As Long
        Dim Left As Long
        Dim Height As Long
        Dim Width As Long
        Call oView.GetWindowExtents(Top, Left, Height, Width)
        Debug.Print Top
        Debug.Print Left
        Debug.Print Height
        Debug.Print Width
    Next
End Sub
You could store and retrieve the data in each document using attributes. See this topic in the API help:
Inventor API User's Manual > Custom Data > Working with Attributes
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
GeorgK
Hello Wayne,
thanks for your help. I tried it. Why is the new form smaller when I use the values for top, left, height and width?
Georg
wayne.brill
Hi Georg,
Yes I see the behavior. However in my tests I see height and width increasing in size by 4 each time I run the code.
Instead of using GetWindowExtents just get the values directly. This kept the sizes the same in my test.  (loops 10 times to test)
 Public Sub Views_Test2()
    Dim oActView As View
    Set oActView = ThisApplication.ActiveView
    Dim oViews As Views
    Dim oView As View
    Dim i As Integer
    For i = 0 To 10
        Dim Top As Long
        Top = oView.Top
        Dim Left As Long
        Left = oView.Left
        Dim Height As Long
        Height = oView.Height
        Dim Width As Long
        Width = oView.Width
        Debug.Print Top
        oView.Top = Top
        Debug.Print Left
        oView.Left = Left
        Debug.Print Height
        oView.Height = Height
        Debug.Print Width
        oView.Width = Width
    Next
    Next i
End Sub
Wayne
Wayne Brill
GeorgK
Hello Wayne,
thanks. That solves the problem.
Georg
