ApprenticeServerDrawingDocument fails to return RequiresUpdate property
psaarloos
psaarloos
I am trying to read the RequiresUpdate property of a ApprenticeServerDrawingDocument in a console application, but it fails all the time. How should I read this property from a console application?
 Inventor.ApprenticeServerComponent app = new Inventor.ApprenticeServerComponent();
                Inventor.ApprenticeServerDrawingDocument doc = app.Open(file) as Inventor.ApprenticeServerDrawingDocument;
                Console.WriteLine(doc.RequiresUpdate.ToString());
Is Invoking an option? Any sample code for that?
Pim Saarloos
Pim Saarloos
Product Manager
If my post answers your question, please click the "Accept as Solution" button. Kudos are much appreciated!
adam.nagy
Autodesk Support
Autodesk Support
Hi Pim,
I guess you too get the error:
{"Not implemented (Exception from HRESULT: 0x80004001 (E_NOTIMPL))"}
... which means that it's not implemented for ApprenticeServerDrawingDocument. That property is coming from the base class ApprenticeServerDocument that's why it's listed for ApprenticeServerDrawingDocument as well, even though it's not available.
It works for part and assembly documents.
Cheers,
Adam Nagy
Autodesk Platform Services
psaarloos
Hi Adam,
That's indeed the same error. Thanks for your explanation. Too bad it's not available on drawing documents.
Pim
Pim Saarloos
Product Manager
maxim.teleguz
did you ever get a solution to this?
