iLogic to Update Custom Mass Property with Model States
arkelec
arkelec
I have some code to iterate through the members of an iPart, to push the 'MassProperties.Mass' value to a custom parameter & populate a column in the iPart Excel table.
I have some code to do the same for the selected instance of an equivalent Part with Model States, but only for that selected Model State instance.
Is there a way of using iLogic to iterate though each Model Stare in the Part, to push the mass value to the custom iProperty?
Also, is the same possible for Assembly files?
bradeneuropeArthur
Then you need for each modelstate a Iproperty like:
Modelstate 1 = wms1
Modelstate 2 = wms2
Etc
Is that ok?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
arkelec
Thanks @bradeneuropeArthur.
A bit of further scouting found this thread: https://forums.autodesk.com/t5/inventor-programming-ilogic/calculate-mass-of-parts-in-an-assembly/td...
I used some of the code that @WCrihfield posted, so thanks for that.
In the event that my code helps anyone else, here it is:
Sub Main()
' Notes:
' Vars:
Dim oMass As Double
Dim strMass As String
' set number of decimal places:
Dim strDP As String = InputBox("Enter Number for DP " & strDP & "", "Set Decimal Places")
Dim intDP As Integer = (Convert.toInt32(strDP))
' Get the active document:
Dim oDocType = ThisDoc.Document.DocumentType
' Code for PART:
If oDocType = DocumentTypeEnum.kPartDocumentObject Then
	Dim oPartDoc As PartDocument = ThisDoc.Document
	Dim oPartDef As PartComponentDefinition = oPartDoc.ComponentDefinition
Dim oMSs As ModelStates = oPartDoc.ComponentDefinition.ModelStates
	If oMSs.MemberEditScope <> MemberEditScopeEnum.kEditActiveMember Then
		oMSs.MemberEditScope = MemberEditScopeEnum.kEditActiveMember
	End If
' Iterate through Model States:
Dim oOrigMS As ModelState = oMSs.ActiveModelState
	For Each oMS As ModelState In oMSs
		oMS.Activate
		Dim oMSDoc As PartDocument = oMS.FactoryDocument
		'oMSDoc.Rebuild2(True) 'helps ensure all updated, but may not be necessary (may take extra time)
		oMass = oPartDoc.ComponentDefinition.MassProperties.Mass
		oMass = oPartDoc.UnitsOfMeasure.ConvertUnits(oMass, oPartDoc.UnitsOfMeasure.MassUnits, Inventor.UnitsTypeEnum.kKilogramMassUnits)
		oMass = Round(oMass, intDP)
		Dim c_Mass As String = fnPropGetVal("c_Mass", "")
		iProperties.Value("Custom", "c_Mass") = oMass & " kg"
	Next 'oMS
	oOrigMS.Activate
	If oPartDoc.RequiresUpdate Then oPartDoc.Update2(True)
' Code for ASSEMBLY:
ElseIf oDocType = DocumentTypeEnum.kAssemblyDocumentObject Then
	Dim oAssemblyDoc As AssemblyDocument = ThisDoc.Document
	Dim oAssemblyDef As AssemblyComponentDefinition = oAssemblyDoc.ComponentDefinition
Dim oMSs As ModelStates = oAssemblyDoc.ComponentDefinition.ModelStates
	End If
		oMS.Activate
		Dim oMSDoc As AssemblyDocument = oMS.FactoryDocument
		oMass = oAssemblyDoc.ComponentDefinition.MassProperties.Mass
		oMass = oAssemblyDoc.UnitsOfMeasure.ConvertUnits(oMass, oAssemblyDoc.UnitsOfMeasure.MassUnits, Inventor.UnitsTypeEnum.kKilogramMassUnits)
	Next 'oMS
	oOrigMS.Activate
	If oAssemblyDoc.RequiresUpdate Then oAssemblyDoc.Update2(True)
	End If
End Sub
'Use:		Check for missing user defined property types
'Params:	PropName - passed in name to check
'			MissingSetVal - optional value to pass to the selected property set by default to empty string
'			Doc - Name of the document to search for the attached property type defined as PropName
'Returns:  	A value held by the selected PropName object as an object - this could be text, bool or numeric.
'On Error:  Returns -1. this can be tested and signalled to the user for further investigation.
Function fnPropGetVal(PropName As String,
	Optional oMissingSetVal As Object = "",
	Optional Doc As Inventor.Document = Nothing) As Object
	Dim oReturnVal As Object
	If Doc Is Nothing Then Doc = ThisDoc.Document 'set to current doc..
	'define a property set object from the API
	Dim CustomPropSet As Inventor.PropertySet = Doc.PropertySets.Item("Inventor User Defined Properties")
		'does the requested object exist?
			Try
			oReturnVal = CustomPropSet.Item(PropName).Value
			Catch
			'not found so create this object defined as PropName in the selected document and apply a value..
			Dim oTransaction As Inventor.Transaction
			Try
			'Modify the current database and add a new param to user defined properties..
			oTransaction = ThisApplication.TransactionManager.StartTransaction(Doc,"Create property """ & PropName & """")
			CustomPropSet.Add(oMissingSetVal, PropName)
			oTransaction.End
			oReturnVal = oMissingSetVal
			'Successfully created the object and set its value..
			Catch
			'failed to create - may be a permissions error..
			If Not oTransaction Is Nothing Then oTransaction.Abort
			oReturnVal = -1 'Unable to create.
			End Try
			End Try
			'all done so..
			Return oReturnVal
			End Function
