iLogic to see if Custom Parameter is set to Export, then either Set to Export or not.
arkelec
arkelec
Is this possible?
A custom parameter xLength already exists in a part file, but may or may not be set to export.
I'd like to check, by running some code launched from a form button & then set the status.
What I can't work out, is how to read a specific custom parameter (the correct syntax).
Thanks in advance.
arkelec
Found the answer (well partially):
Sub Main()
'Vars
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim oFormat As CustomPropertyFormat
'============ Custom User Parameter Property Format =============
	oParam = oDoc.ComponentDefinition.Parameters("xLength")
	If oParam.ExposedAsProperty = False Then 'Flag for Export
		oParam.ExposedAsProperty = True
		oFormat = oParam.CustomPropertyFormat
		oFormat.PropertyType = Inventor.CustomPropertyTypeEnum.kTextPropertyType
		oFormat.Precision = Inventor.CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision
		oFormat.ShowUnitsString = False
		oFormat.ShowLeadingZeros = False
		oFormat.ShowTrailingZeros = False
	Else If oParam.ExposedAsProperty = True Then 'Flag for Export
	End If
End Sub
bradeneuropeArthur
Public Sub Main
	Dim a As Inventor.Application = ThisApplication
 	Dim p As Inventor.PartDocument = a.ActiveDocument
	Dim c As Inventor.PartComponentDefinition = p.ComponentDefinition
	MsgBox (c.Parameters.Item("xLength").ExposedAsProperty)
	End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
