Global update model in Ilogic before going on with rest of script
peterd123
peterd123
I am having trouble getting this to work.
I have VBA running in Excel that cycles through many iterations of an assembly changing the parameters in each cycle.
Simplified, on the excel side it changes the parameters, saves the file and then waits for 30 sec before repeating.
Inventor is detecting the change via a trigger (set in excel with a NOW()).  Then it should update model, and then save as dwg and obj (with name brought in from excel).
PROBLEM:
What I am realizing is that it is not saving them with the current model, but rather the model of the previous iteration.
Below is the ilogic script, with ' comments of things I have tried to no avail.  Any suggestions on how to force update before proceeding with rest of script?
trigger = ExcelTrigger
brand = GoExcel.CellValue("dimensions.xlsm", "Sheet2", "B7")
family = GoExcel.CellValue("dimensions.xlsm", "Sheet2", "B8")
full_name = GoExcel.CellValue("dimensions.xlsm", "Sheet2", "B9")
part_num = GoExcel.CellValue("dimensions.xlsm", "Sheet2", "B10")
file_name = GoExcel.CellValue("dimensions.xlsm", "INPUT", "B2")
file_directory = GoExcel.CellValue("dimensions.xlsm", "INPUT", "G2")
'RuleParametersOutput()
'InventorVb.DocumentUpdate()
Call ThisApplication.CommandManager.ControlDefinitions.Item("AppLocalUpdateCmd").Execute
Call ThisApplication.CommandManager.ControlDefinitions.Item("AppGlobalUpdateWrapperCmd").Execute
System.Threading.Thread.CurrentThread.Sleep(15000)
'iLogicVb.UpdateWhenDone = True
'ThisApplication.DocumentUpdate = True
'Parameter.UpdateAfterChange = True
'ThisApplication.ActiveDocument.Update2
'Application.Wait (Now + TimeValue("0:00:12"))
' didnt work ThisApplication.ActiveView.Update()
' didnt work ThisApplication.ActiveDocument.Rebuild
' didnt work ThisApplication.ActiveDocument.Update()
'Save .igs in new file path
ThisDoc.Document.SaveAs(ThisDoc.Path + file_directory + file_name + ".obj", True)
ThisDoc.Document.SaveAs(ThisDoc.Path + file_directory + file_name + ".dwg", True)
GoExcel.DisplayAlerts = False
GoExcel.Close
gcoombridge
How about a rebuild-all prior to the save? This may slow things down but might force an update..
ThisDoc.Document.Rebuild()
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
bradeneuropeArthur
Dim a As Inventor.Application = ThisApplication
Dim b As Inventor.Document = a.ActiveDocument
b.Rebuild2(True)
If b.RequiresUpdate = True Then
b.Update2(True)
b.Save2(True)
With this it should work!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
peterd123
I tried this out.  I notice that the output files are being created about 5 sec before the model updates.
greggeorgi
Your thread.sleep might not be helping anything. Worst case, it is actually pausing the command manager execution.
You can try using Execute2 and/or DoEvents.
Execute2(True) might be the same as regular Execute, not sure, I only use Execute2. (Executes synchronously if true, asynchronously if false)
DoEvents will essentially pause the iLogic thread, process inventor stuff, then return. Some might say its not good practice to use it, but the way Inventor is programmed, it is basically required in certain cases. This may be your best bet after running the commands. (maybe a DoEvents after each execute)
Call ThisApplication.CommandManager.ControlDefinitions.Item("CMD").Execute2(True)
Call ThisApplication.UserInterfaceManager.DoEvents
If there is some sort of flag that can be set, you can also use DoEvents to wait for the process to definitely finish
dim flag as boolean = false
While not flag
    'check if flag should be set to true, or use an event?
End While
peterd123
Adding this after the model update and before the saves seems to have done the trick:
Thanks!
maxim.teleguz
ThisApplication.ScreenUpdating = True
iLogicVb.Automation.RulesOnEventsEnabled = True
ThisApplication.SilentOperation = False
UpdateRevBlockOnSyncProp = 1
'https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Vault/files/GUID-DFE2BDB7-4A6D-49D7-9083-18DCB20B7505-htm.html
'activecmd = ThisApplication.CommandManager
'If activecmd.ActiveCommand = activecmd.ActiveCommand Then
'MsgBox(activecmd.ActiveCommand)
'End If
SendKeys.SendWait("{ESC}")
AppActivate(ThisApplication.Caption)
On Error Resume Next
Dim selectCmd As ControlDefinition
    selectCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppContextual_CancelCmd")
    selectCmd.Execute
ThisApplication.CommandManager.ControlDefinitions.Item("VaultRevisionBlockTableNode").Execute2(False)
a = iProperties.Value("Project", "Revision Number")
iProperties.Value("Custom", "REV") = a
here is code updating the revision block. This works really well in canceling out any commands that are running first.
