ilogic to change factory part - syntax error?
chrisjspower
Message 1 of 8
chrisjspower
Hi all, I'm learning how to use ilogic for inventor.
My current issue that I can't seem to get around is a syntax error.
I have obtained the correct syntax from the Autodesk website I need to use but I can't see where I am entering it incorrectly.
I am using assembly, with various iparts
I have a user parameter I named "Tank_Type_STANDARD" which I want to control the factory ipart that is loaded to the assembly. the goal is to create a form that can produce different variations of an assembly through basic changes made to the form.
my failing rule is as follows:
If Tank_Type_STANDARD = 1
Then iPart.ChangeRow("Tank_wall_base", "Tank_Lower_Section_01")
ElseIf Tank_Type_STANDARD = 2
Then iPart.ChangeRow("Tank_wall_base", "Tank_Lower_Section_02")
Have I approached this problem incorrectly? can my goal be achieved? I will continue to try and solve this problem in the meantime. Any and all assistance is greatly appreciated.
regards,
Chris
Replies (7)
Message 3 of 8
chrisjspower
Several hours in and I can't see where these suggestions relate or how to apply them. Everything I try comes back with syntax errors or does nothing.
This should be a pretty basic function, or I'm going about it the wrong way. I just want to change an ipart in assembly without manually doing so in the assembly tree.
thanks
Edit*
Not sure if part name is stabilized so will try this now
Message 4 of 8
MechMachineMan
FTFY
Structure is important in coding. The 'then'  needs to be at the end of the line (or not exist at all in some programming languages)
If Tank_Type_STANDARD = 1 Then
ElseIf Tank_Type_STANDARD = 2 Then
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 5 of 8
chrisjspower
Like this?
If Tank_Type_STANDARD = 3
Then iPart.ChangeRow("Tank_Lower_Section", "T03")
Else If Tank_Type_STANDARD = 4
Then iPart.ChangeRow("Tank_Lower_Section", "T04")
 i get a syntax error on line 2 & 4 still whereas placing "then" at the "end" of line 1 & 2 produces no error.
thanks
Message 6 of 8
chrisjspower
Okay thanks that got me a step further, now i just have to figure out why it isn't finding the row.
I get this message:
"Error in rule: "rule", in document: "Assembly.iam"
iPart.ChangeRow: No iPart row with the specification "anthing i enter here" was found in the component "ipart".
when it refers to the row do I enter the member name, the part number or the number to the far left of the table?
thanks
Message 7 of 8
MechMachineMan
Yeah, could be it!
Simply trying things out and seeing what happens will probably get your results a lot faster than posting back to the forums every time.
Sounds like a reasonable assumption that it could be looking for information in the first column of the iPart table.
Or maybe the format of the table is off too.
You could always review the documentation in the help files about iPart iLogic too.
Justin K
Message 8 of 8
chrisjspower
Oh I wasn't waiting for the solution, I was working on it the whole time, trying everything.
In the end I re-started from scratch and used the same ilogic i started with and it worked. when I am back at work I will repost with my findings.
Thanks for your help!
