iLogic or VBA - List all reference part within a assmbly model
Hi all
has anyone tried to check and list all the reference parts within a 3D assembly model?
like check if all my parts at set to BOM structure Default instead of Reference
be nice if there a way to pop up a window to show the parts set to reference
this routine will save me a lot of time
thanks
ianteneth
Hi! I know this is an old post, but in case this helps anyone in the future here is a simple iLogic script to list components in an assembly that have a BOM structure set to reference. Note that this script won't check parts inside of sub assemblies.
Sub Main()
    ' Get current assembly. Assume an assembly is open
    Dim assembly As Inventor.AssemblyDocument = ThisDoc.Document
	' Variable to store the results
	Dim output As String = ""
	' Loop through each component in the assembly
	For Each occurrence As Inventor.ComponentOccurrence In assembly.ComponentDefinition.Occurrences
		' Determine the BOM structure and see if it is referenced
		If occurrence.BOMStructure = Inventor.BOMStructureEnum.kReferenceBOMStructure Then
			' Add component to output since the BOM structure is referenced
			output += occurrence.Name & vbNewLine
	Next occurrence
	' Pop up a window with the results
	MessageBox.Show(output)
End Sub
