iLogic thisdoc.Document.SaveAS
Hello fellows,
i've written a small configurator rule to standardize the output of a simple machine of my technical office.
No one other of the draftsmen under my responsability have the experience to mess around with ilogic rules, and i'm trying to make them use this configurator with 0 chances of fault.
Basically when you open the "base" file (an assembly with a small number of iparts and iassembly) a rule will pop up and they configure the product with a lot of input box list.
When the machine is configured on screen i want to automatically "save as", because i dont want my draftsmen to mess around with my configurator. So the rule must save the doc as ->pop up the wizard to save as... but i get an error.
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
iLogic needs, questions, issues and etc should be posted in the Inventor customization forum for best results
I will have the moderator relocate your posting there to best suit your needs.
https://forums.autodesk.com/t5/inventor-customization/bd-p/120
Mark Lancaster
bradeneuropeArthur
can you upload the code?
what is the new filenameextension look like?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
