iLogic: Surpression order
hi,
So I got this small inspection gate that I need a left and right version of.
Wrote my iLogic code and everything works when I select "Placing G" under parameter. But when selecting "Placing F" it just surpresses too many features.
I have attached the part file, if someone wants a crack at it
MechMachineMan
If you were to try suppressing the features in the order they were written in your rule, you would have the same results.
You need to carefully plan out your code so that it works from top to bottom in terms of suppression, instead of bottom to top.
It's all about the order you have, which I believe you should be able to figure out with much further explanation.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
