iLogic save as
iLogic save as
iLogic save as
Hi everyone,
i'm trying to add some code to my parametrization procedure.
I wuold like to save as the file by a name linked by a parameter, how could I do it?
now i'm using:
Dim newFileName as string
newFileName = InputBox("Prompt", "Title", "Default Entry")
ThisDoc.Document.SaveAs(newFileName , True)
but when i compile it says:
HRESULT: 0x80004005 (E_FAIL))
how could I solv it?
thanks a lot in advance.
MechMachineMan
Try using ThisApplication.ActiveDococument rather than ThisDoc.
Also, the first time a new document is saved, you should set the SaveCopyAs flag to false.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thanks for your help, but I found a rule that does what I want and also permit to select the folder!
