Embossed Text
Embossed Text
alanrichardson
Message 1 of 10
Embossed Text
alanrichardson
Hi
Can anyone help - I'd like to be able to Emboss the Text contained in the iPorperties, Stock Number field onto a face of my choosing at the point of selection. (this would be an etch).
I believe it needs to be done via VBA but since I'm an absolute novice with VBA I'm struggling.
I did find some code (below, courtesy of Dshortway) that works, but I've no idea how to modify it for my purposes.
Can any VBA guru point me in the right direction?
Copy/paste this code whitin a module
Option Explicit
Public Sub EmbossedText()
    ' Create a new clsSelect object.
    Dim oSelect As New clsSelect
    ' Set a reference to the part component definition.
    ' This assumes that a part document is active.
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    ' Call the pick method of the clsSelect object and set
    ' the filter to pick any face.
    Dim oFace As Face
    Set oFace = oSelect.Pick(kPartFaceFilter)
    ' Check to make sure an object was selected.
    If Not oFace Is Nothing Then
        Dim oSketch As PlanarSketch
        Set oSketch = oCompDef.Sketches.Add(oFace, True)
        oSketch.Name = "Embossed text"
    ' Create text with simple string as input.  Since this doesn't use
    ' any text overrides, it will default to the active text style.
    Dim sText As String
    Dim oTextBox As TextBox
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    ' Simple single line text.
    sText = "Here is the last and final line of text."
    Set oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(oSketch.OriginPointGeometry.X, _
                                                oSketch.OriginPointGeometry.Y), sText)
    With oTextBox
        .VerticalJustification = kAlignTextMiddle
        .HorizontalJustification = kAlignTextCenter
    End With
    ' Add the text box to an object collection
    Dim oPaths As ObjectCollection
    Set oPaths = ThisApplication.TransientObjects.CreateObjectCollection
    oPaths.Add oTextBox
    ' Create a profile. Calling the AddForSolid method without any
    ' arguments will result in a profile containing all possible
    ' paths in the sketch. By passing in the text box, the profile
    ' is restricted to the input text path.
    Dim oProfile As Profile
    Set oProfile = oSketch.Profiles.AddForSolid(False, oPaths)
    ' Extrude the text.
    Dim oExtrudeDef As ExtrudeDefinition
    Set oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kCutOperation)
    Call oExtrudeDef.SetDistanceExtent(0.25, kNegativeExtentDirection)
    Dim oExtrude As ExtrudeFeature
    Set oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
End Sub
Copy/paste this code in a class named "clsSelect" (Inventor API help)
Option Explicit
' Declare the event objects
Private WithEvents oInteractEvents As InteractionEvents
Private WithEvents oSelectEvents As SelectEvents
' Declare a flag that's used to determine when selection stops.
Private bStillSelecting As Boolean
Public Function Pick(filter As SelectionFilterEnum) As Object
    ' Initialize flag.
    bStillSelecting = True
    ' Create an InteractionEvents object.
    Set oInteractEvents = ThisApplication.CommandManager.CreateInteractionEvents
    ' Ensure interaction is enabled.
    oInteractEvents.InteractionDisabled = False
    ' Set a reference to the select events.
    Set oSelectEvents = oInteractEvents.SelectEvents
    ' Set the filter using the value passed in.
    oSelectEvents.AddSelectionFilter filter
    ' Start the InteractionEvents object.
    oInteractEvents.Start
    ' Loop until a selection is made.
    Do While bStillSelecting
        ThisApplication.UserInterfaceManager.DoEvents
    Loop
    ' Get the selected item. If more than one thing was selected,
    ' just get the first item and ignore the rest.
    Dim oSelectedEnts As ObjectsEnumerator
    Set oSelectedEnts = oSelectEvents.SelectedEntities
    If oSelectedEnts.Count > 0 Then
        Set Pick = oSelectedEnts.Item(1)
    Else
        Set Pick = Nothing
    ' Stop the InteractionEvents object.
    oInteractEvents.Stop
    ' Clean up.
    Set oSelectEvents = Nothing
    Set oInteractEvents = Nothing
End Function
Private Sub oInteractEvents_OnTerminate()
    ' Set the flag to indicate we're done.
    bStillSelecting = False
End Sub
Private Sub oSelectEvents_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View)
End Sub
Inventor 2020, Windows 10
Replies (9)
Message 2 of 10
Balaji_Ram
Hi Alan,
Here are the changes to get the stock number at the selected point :
Inside the clsSelect class :
Private ptSelected As Inventor.Point
Private Sub oSelectEvents_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal modelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View)
    Set ptSelected = modelPosition
End Sub
Public Property Get SelectedPoint() As Variant
    Set SelectedPoint = ptSelected
End Property
In the module that creates embossed text :
    Dim oFace As Face
    Dim ptSelected As Inventor.Point
    Set ptSelected = oSelect.SelectedPoint
After you have the selected point, use it to create the sketch :
        'Set oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(oSketch.OriginPointGeometry.X, _
        '                                           oSketch.OriginPointGeometry.Y), sText)
        Set oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(ptSelected.X, _
                                                   ptSelected.Y), sText)
Modify the text contents to use the stock number
        ' Get the design tracking property set.
        Dim invDesignInfo As PropertySet
        Set invDesignInfo = ThisDocument.PropertySets.Item("Design Tracking Properties")
        ' Get the stock number property.
        Dim invPartNumberProperty As Property
        Set invPartNumberProperty = invDesignInfo.Item("Stock Number")
        sText = invPartNumberProperty.Value
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Message 3 of 10
alanrichardson
Hi Balaji,
Thanks for the information, being the total VBA novice that I am, having attempted to follow you instructions I have a problem with PtSelected Variable.
I have modified the code, but not confidently. Here is my Latest Effort.
clsSelect Code
Option Explicit
    ' Initialize flag.
    Loop
    Else
        Set Pick = Nothing
    ' Clean up.
End Function
End Sub
End Sub
End Property
Module Code
Option Explicit
    Dim oFace As Face
    ' Set the point selected
       Dim sText As String
       With oTextBox
       End With
       oPaths.Add oTextBox
       ' Extrude the text.
End Sub
The code compiles but when I select a face I get the message  variable not defined [ptSelected]  (see attached clip)
Where should I have set this variable?
(I've attached the part file I'm using, if that helps)
Regards and thanks
Alan
Message 4 of 10
Balaji_Ram
Hi Alan,
That should be a private variable of the "clsSelect" class and declared at the top. For example, below the line that declares
Balaji
Balaji
Message 5 of 10
alanrichardson
Hi Balaji,
Sorry to be a pain . . .
I've added the variable, but I get a runtime error when I select a face. (Method 'ADD' of object 'Extrude Feature' failed).
I also think my pick point is incorrect.
The sketch 'embossed text' is created but the creation point appears to be off the face.
Could you take a look at my IPT file please?
Regards
Alan
Message 6 of 10
Balaji_Ram
Hi Alan,
Not a problem at all.
I have attached the modified part file.
Because the stock number (sText) is required for the sketch creation, it is to be moved prior to this line :
Balaji
Balaji
Message 7 of 10
alanrichardson
Hi Balaji
Thanks for the information, didn't quite understand the iLogic in the attached file . . .
I have moved the required code and I'm now getting the stocknumber into my part.
However, it's not being placed at the point that the face is selected. I selected the approx centre of the yellow face(see attached pic) and the text is
being placed off the face to the lower left hand side.
Do I have some more code incorrectly placed?
MODULE CODE
Option Explicit
Public Sub EmbossedTextVBA()
    Dim oFace As Face
       Dim sText As String
       With oTextBox
       End With
       oPaths.Add oTextBox
       ' Extrude the text.
       'On Error Resume Next
End Sub
CLASS (CLSSELECT CODE)
Option Explicit
    ' Initialize flag.
    Loop
    Else
        Set Pick = Nothing
    ' Clean up.
End Function
End Sub
End Sub
End Property
I appreciate the help, you have no idea, potentially, how much time this will save me in my daily work.
Alan
Message 8 of 10
Balaji_Ram
Hi Alan,
I can reproduce the behavior with the part that you shared.
I am looking into this and will get back to you soon.
Balaji
Balaji
Message 9 of 10
Balaji_Ram
Hi Alan,
Please try this code that converts the selected point coordinates from model to sketch coordinates.
The "öPnt2d" which is now in sketch coordinates can be used with the "AddFitted" method.
       Dim oPnt2d As Point2d
       Set oPnt2d = oSketch.ModelToSketchSpace(ptSelected)
       Set oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(oPnt2d.X, _
                                                   oPnt2d.Y), sText)
Also, please ignore the iLogic code in the file that i earlier shared, I was trying that out for another query from a developer.
Balaji
Balaji
Message 10 of 10
alanrichardson
Hi Balaji
That's absolutely great!
Works a treat!
Thanks & Regards
Alan
