Ilogic rule question about export to dwg
EMVC
Message 1 of 30
EMVC
Hello
Is it possible to make a rule to export all parts of this assembley idw to single dwg sheets, with filename from part table (same as balloon) on each dwg + thinkness +qty from parttable
we must make plasma files in dwg from each part, and it is a lot of work during a year
qty is important also thinkness, but idont know how to get that info in part table, maybe use length ?
a stair will be made by several parts of thinkness
Steps/Landing (sheet metal) should also be unfolded in dwg
Part table is not complete here, this is just an example,
Replies (29)
Message 21 of 30
EMVC
Hello
Yes
Message 22 of 30
chandra.shekar.g
Autodesk Support
Autodesk Support
@EMVC,
Try workaround suggestions in the below screencast link.
https://autode.sk/2PiwSVZ
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 23 of 30
EMVC
Hello
Sorry i missunderstood, it is sheet metal export from Assembley thats come out mirror it come out with front view but i must come out backview
See i have mark in blue on assy and it comes out like picture below, then the scribe will be mirror on plasma cutter
Message 24 of 30
chandra.shekar.g
Autodesk Support
Autodesk Support
@EMVC,
It's not a sheet metal part and it's a regular part document. you can follow same workaround which is suggested for assembly.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 25 of 30
EMVC
Hello
Ok i will try this, so there is no workaround i vba
Message 26 of 30
EMVC
Hello
i can just also open dwg and mirror it, that will also work
Message 27 of 30
EMVC
Hello
Because there wil maybe be problem with this stair, i will check with that,
Message 28 of 30
EMVC
Hello
is it posible to stop vba during export to select view befor export
Message 29 of 30
EMVC
Hello
I will play a little bit more with view but it seems like i must do it it autocad, dosent matter how i save part in inventor it will come out mirror to what i want,
Another question is , can it be done to remove a part of name look below
Call oCompDef.DataIO.WriteDataToFile(sOut, oFolder & "\" & oAsmName & "-" & oFileName & ".dwg")
Message 30 of 30
EMVC
Hello
I solved it, i am try to learn a little bit
Call oCompDef.DataIO.WriteDataToFile(sOut, oFolder & "\" & oAsmName & "-" & Mid(oFilename, 13) & ".dwg")
