Ilogic rule question about export to dwg
EMVC
Message 1 of 30
EMVC
Hello
Is it possible to make a rule to export all parts of this assembley idw to single dwg sheets, with filename from part table (same as balloon) on each dwg + thinkness +qty from parttable
we must make plasma files in dwg from each part, and it is a lot of work during a year
qty is important also thinkness, but idont know how to get that info in part table, maybe use length ?
a stair will be made by several parts of thinkness
Steps/Landing (sheet metal) should also be unfolded in dwg
Part table is not complete here, this is just an example,
Replies (29)
Message 2 of 30
EMVC
I also forget files in a folder in same as idw file
And i need cut lines and scribe lines thats also tricky i think
Message 3 of 30
EMVC
Hello
here i post page 2 , is the a way to export this parts in a single idw with multiple parts into separte dwg with file name and pcs if it is possible, sheet metal as in steps i can unfold and put on idw sheet, i can also make cut and scribe lines in autocad after convert, in this way i also save time
Message 4 of 30
chandra.shekar.g
Autodesk Support
Autodesk Support
@EMVC,
Is it possible to share non confidential files which contains expected result and input files?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 5 of 30
EMVC
Hello
here it is, Thank you for ask, scribe lines i think i must make in Autocad after export,
Message 6 of 30
EMVC
Hello
i forgot steps and landing, use this instead
Message 7 of 30
chandra.shekar.g
Autodesk Support
Autodesk Support
Message 8 of 30
EMVC
Hello
I think the first link is what i am looking for, can it export to dwg instead
We must draw everything in sheet metal as i understand,  now we have both sheet metal and standart.ipt
I can not get it to run it makes folder but no files
Message 9 of 30
chandra.shekar.g
Autodesk Support
Autodesk Support
@EMVC,
Try below modified VBA code to export into dxf.
Sub Export_Sheetmetal()
    'define the active document as an assembly file
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    Dim oAsmName As String
    oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) - 4)
    'check that the active document is an assembly file
    If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
        MsgBox ("Please run this rule from the assembly file.")
        Exit Sub
    End If
    'get user input
    Result = MsgBox("This will create a DXF file for all of the asembly components that are sheet metal." _
    & vbLf & "This rule expects that the part file is saved." _
    & vbLf & " " _
    & vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
    & vbLf & "This could take a while.", vbYesNo, "iLogic  - Batch Output DXFs ")
    If Result = vbNo Then
        Exit Sub
    End If
    Dim oPath As String
    Dim iSplit As Integer
    iSplit = InStrRev(oAsmDoc.FullDocumentName, "\")
    oPath = Left(oAsmDoc.FullDocumentName, iSplit - 1)
    Dim oDataMedium As DataMedium
    Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    'get DXF target folder path
    Dim oFolder As String
    oFolder = oPath & "\" & oAsmName & " DXF Files"
    'Check for the DXF folder and create it if it does not exist
    If Len(Dir(oFolder, vbDirectory)) = 0 Then
        MkDir oFolder
    End If
    '- - - - - - - - - - - - -Component  - - - - - - - - - - - -
    'look at the files referenced by the assembly
    Dim oRefDocs As DocumentsEnumerator
    Set oRefDocs = oAsmDoc.AllReferencedDocuments
    Dim oRefDoc As Document
    Dim iptPathName As String
    'work the the drawing files for the referenced models
    'this expects that the model has been saved
    For Each oRefDoc In oRefDocs
        If oRefDoc.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
            Dim oDrawDoc As PartDocument
            Set oDrawDoc = ThisApplication.Documents.Open(oRefDoc.FullDocumentName, True)
            oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) - 4)
            'Set the DXF target file name
            oDataMedium.FileName = oFolder & "\" & oFileName & ".dxf"
            Dim oCompDef As SheetMetalComponentDefinition
            Set oCompDef = oDrawDoc.ComponentDefinition
            If oCompDef.HasFlatPattern = False Then
                oCompDef.Unfold
            Else
                oCompDef.FlatPattern.Edit
            End If
            Dim sOut As String
            sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE"
            Call oCompDef.DataIO.WriteDataToFile(sOut, oFolder & "\" & oFileName & ".dxf")
            'just for check its works coretcly
            'i=MessageBox.Show(oDataMedium.FileName, "Title",MessageBoxButtons.OKCancel)
            'MessageBox.Show(i,"title",MessageBoxButtons.OK)
            'If i=2 Then
                'Exit Sub
            'End If
            oCompDef.FlatPattern.ExitEdit
            oDrawDoc.Close
        End If
    Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 10 of 30
EMVC
Hello
This worked, is it possible to remove bend lines and convert to dwg instread of dxf
in pcs also something it possible to implent
Message 11 of 30
EMVC
Hello
i covert a standard .ipt to sheet metal , it seems like the part will come out mirror se pictures, Mirror 1.JPGMirror 2.JPG
Message 12 of 30
EMVC
Hello
I modified it a littlebit so i get ctlines and scribe lines se red line, but how to add color to the layers and i want to remove tangent layer
Exit Sub
End If
'get user input
& vbLf & " " _
Exit Sub
End If
Dim oPath As String
MkDir oFolder
End If
oCompDef.Unfold
Else
End If
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=Cut&featureprofilesdownLayer=Scribe&interiorprofilesLayer=Cut"
sOut = "FLAT PATTERN DXF?AcadVersion=2004&tangentLayer=False"
'If i=2 Then
'Exit Sub
'End If
oDrawDoc.Close
End If
Next
End Sub
Message 13 of 30
EMVC
Hello
i add this when i got color, but i still miss to remove bend lines i also see that i must make arc center invisible
and make part not mirror as picture above
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=Cut&OuterProfileLayerColor=0;255;0&featureprofilesdownLayer=Scribe&featureprofilesdownLayerColor=255;0;255&interiorprofilesLayer=Cut"
Message 14 of 30
EMVC
Hello
I have tried to modify it a little bit, it works but it is not perfect modify se in red
I hope now to implent so part dont comes out as mirror se picture above
I hope also to get part will come in diffrent folder after thickness if it is possible also pcs so i dont have to do that manuell
Sub Export_Plasma()
Exit Sub
End If
'get user input
Result = MsgBox("This will create a DWG file for all of the asembly components that are sheet metal." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DWG for all of the assembly components?" _
& vbLf & "This could take a while.", vbYesNo, "iLogic - Batch Output DWGs ")
Exit Sub
End If
Dim oPath As String
oFolder = oPath & "\" & oAsmName & " Plasma Filer"
MkDir oFolder
End If
'Set the DWG target file name
oDataMedium.FileName = oFolder & "\" & oFileName & ".dwg"
oCompDef.Unfold
Else
End If
Dim sOut As String
sOut = "FLAT PATTERN DWG?AcadVersion=2004&OuterProfileLayer=Cut&OuterProfileLayerColor=0;255;0&featureprofilesdownLayer=Scribe&featureprofilesdownLayerColor=255;0;255&interiorprofilesLayer=Cut&InvisibleLayers=IV_BEND_DOWN;IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL"
Call oCompDef.DataIO.WriteDataToFile(sOut, oFolder & "\" & oFileName & ".dwg")
'If i=2 Then
'Exit Sub
'End If
oDrawDoc.Close
End If
Next
End Sub
Message 15 of 30
EMVC
Hello
I added this strings so now it create foldet of thickness and material, but there is something strange we use mm in Norway, in picture below the one folder says 0,500 mm this is 10 mm
The other says Steps sheet tinkness thid is 5 mm
Dim oDef As SheetMetalComponentDefinition
Set oDef = oDrawDoc.ComponentDefinition
Dim oThick As String
oThick = oDef.ActiveSheetMetalStyle.Thickness
Dim oMaterial As String
oMaterial = oDrawDoc.ActiveMaterial.DisplayName
oFolder = oPath & "\" & oAsmName & " Plasma Filer\" & oThick & "-" & oMaterial
MkDir oFolder
End If
Message 16 of 30
EMVC
Hello
i solved everything except mirror on part, so dont care reading the rest of my posts
So everything else works like a charm
Sub Export_Plasma()
Exit Sub
End If
'get user input
& vbLf & " " _
Exit Sub
End If
Dim oPath As String
MkDir oFolder
End If
oFolder = oPath & "\" & oAsmName & " Plasma Filer\" & oThickness & "-" & oMaterial
MkDir oFolder
End If
oCompDef.Unfold
Else
End If
Dim sOut As String
'If i=2 Then
'Exit Sub
'End If
oDrawDoc.Close
End If
Next
End Sub
Message 17 of 30
EMVC
Hello
i was played a little bit and it seems like i have front view i wish to have back view instead
what lines could be added
Message 18 of 30
chandra.shekar.g
Autodesk Support
Autodesk Support
@EMVC ,
Thanks for letting me know that you have solved all your problems.
Can you please explain back view and front view issue with screenshots?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 19 of 30
EMVC
Hello
Here is pictures the first one below is right the second one with green and pink color is mirror, thats my cut and scribe lines, like it is now it will get scribe on the wrong side in plasma, so i mirror in autocad
One question, can qty from i propert be added
Message 20 of 30
chandra.shekar.g
Autodesk Support
Autodesk Support
@EMVC,
Is it main assembly(TB747 12039__TR_1.iam) exported to dwg?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
