- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All,
We currently have an illogic rule that for a given assembly, opens up the individual parts and checks if they have a flat pattern, if they do it exports the part as DXF and names it the same name as the file name. All of that works excellently, however, the DXFs that get created have extra lines (bend lines) and all the line segments are not joined together. Our plasma table requires all contours to be joined to run. Right now we are going in and manually joining the line segments in autocad using the join command. I noticed though that if I use the built in "export face as" command the DXF that gets created has no bend lines and it comes out as a joined contour. I believe the code used to create the actual DXFs in our current rule is utilizing some sort of flat pattern drawing view. I am posting the code below and my questions are;
Could someone help in altering the current code to not export bend lines and make the line segments joined?
OR
Could someone replace the current DXF creation kernel with the "export face as" method?
here is our rule
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
End If
'get user input
RUsure = MessageBox.Show ( _
"This will create a DXF file for all of the assembly components that was created using the sheet metal template." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic - Batch Output DXFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
End If
oPath = "R:\email\Burn Table" 'this will need to be modified for your use
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'get DXF target folder path
oFolder = oPath & "\" & oAsmName
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'- - - - - - - - - - - - -Component - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the drawing files for the referenced models
'this expects that the model has been saved
For Each oRefDoc In oRefDocs
iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
'check that model is saved
If(System.IO.File.Exists(iptPathName)) Then
Dim oDrawDoc As PartDocument
oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
Try
'Set the DXF target file name
ofilename = Left(oRefDoc.displayname, Len(oRefDoc.DisplayName) - 3)
oDataMedium.FileName = oFolder & "\" & oFileName & "dxf"
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDrawDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
End If
Dim sOut As String
'this assigns colors to the different layers, this can also be modified
sOut = "FLAT PATTERN DXF?AcadVersion=2004" _
+ "&OuterProfileLayer=OUTER_PROF&OuterProfileLayerColor=255;165;0" _
+ "&InteriorProfilesLayer=INNER_PROFS&InteriorProfilesLayerColor=124;252;0" _
+ "&FeatureProfileLayer=FEATURE&FeatureProfileLayerColor=255;0;255" _
+ "&ArcCentersLayer=CENTERS&ArcCentersLayerColor=135;206;235" _
+ "&IV_Arc_Centers&InvisibleLayers=IV_Tangent;IV_Bend;IV_Bend_Down;IV_Bend_Up&IV_Arc_Centers&InvisibleLayersColor=135;206;235"
oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
'just for checking to see if its works coretcly
'i=MessageBox.Show(oDataMedium.FileName, "Title",MessageBoxButtons.OKCancel)
'MessageBox.Show(i,"title",MessageBoxButtons.OK)
'If i=2 Then
'Exit Sub
'End If
oCompDef.FlatPattern.ExitEdit
Catch
End Try
oDrawDoc.Close
Else
End If
Next
