iLogic - rule is opening second copy of file?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, everyone,
I'm using iLogic to do a basic Configuration, using an IAM as a template.
The (fully populated) IAM template is opened, with the "iLogic" LOD active. Selections in a form (launched automatically when IAM is opened) drive parameters and rules, to suppress un-needed components, and adjust some dimensions. When all is finished, suppressed components are deleted, the IAM is saved as a new number, and an existing template drawing is opened, re-attached to the new IAM, and saved. This all happens thru the rule.
Everything works perfectly, except...
After the rule ends (I have a message box that verifies this), I get the following message box, even though everything worked fine.
One clue: when the template drawing is opened, the form from the IAM is re-launched. This tells me that it's opening the IAM again, in the background?
The drawing views are based on the Master LOD, not the iLogic LOD. Is this why it's opening the IAM again, and throwing this error?
Vault Professional 2021
