Highlight Part with iLogic
Message 1 of 8
I am writing a program that calculates the price of a part based on an Excel spreadsheet.
The only feature I am missing at the moment is that I would like the program to highlight each part as it steps through them so the user can follow along and see that each part has been calculated.
I am not picky on how the highlighting happens.  It could color the whole part red or something, but it needs to be put back to it's original appearance when the program ends.  I have pasted my code below.  I've included the lines of code that I've been tinkering with for highlighting.
Keep in mind that I'm a very beginner programmer (this is actually my first iLogic program) so if anything looks weird of sub-optimal it's because I don't know any better.  I would also appreciate general comments on how the code could be done better.
Any ideas?
' Get the active assembly document.
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
' Iterate through all of the documents referenced by the assembly.
Dim oDoc As Document
For Each oDoc In oAsmDoc.AllReferencedDocuments
' Verify that the document is a part.
    If oDoc.DocumentType = kPartDocumentObject Then
		Dim oPartDoc As PartDocument = oDoc
		Dim model As String = oPartDoc.DisplayName
		model = model & ".ipt"
		'Manipulate part
		'Highlight part in question
		'Component.Color(oDoc) = "Red"
		oPartDoc.ActiveRenderStyle = oAsmDoc.RenderStyles.Item("Red")
		'Specify Excel file used for pricing
		ExcelFile = "F:\blablabla\Stock Parts Prices.xlsx"
		'Look up whether or not the part is priced by inch or lb in the excel sheet
		Dim CostTypeRow As Integer = GoExcel.FindRow(ExcelFile, "Sheet1", "Stock Type", "=", iProperties.Value(model,"Project", "Stock Number"))
		Dim CostType As String
		If CostTypeRow = -1 Then
			CostType = "NULL"
		ElseIf CostTypeRow > 0 Then
			CostType = GoExcel.CellValue(ExcelFile, "Sheet1", "C" & CostTypeRow)
			'Look up cost of that part
			Cost = GoExcel.CellValue(ExcelFile, "Sheet1", "B" & CostTypeRow)
		If 	CostType = "POUND" Then
			mass = iProperties.Mass(model)
			TotalCost = Cost * mass
			iProperties.Value(model,"Project", "Estimated Cost") = TotalCost
		Else If CostType = "INCH" Then
				Try
					length = Parameter(model, "B_L")
					MessageBox.Show("Detected Length = " & Parameter(model, "B_L"), model)
				Catch
					length = InputBox("Input length of part:", iProperties.Value(model,"Summary", "Title") & " " & iProperties.Value(model,"Project", "Stock Number"), "0")
				End Try
			TotalCost = length * Cost
	Else
Next
MessageBox.Show("Son", "Done")
Replies (7)
Message 2 of 8
MechMachineMan
Something along these lines should work for you.
Dim oACD As AssemblyComponentDefinition
oACD = oAsmDoc.ComponentDefinition
Dim oSS As oAsmDoc.SelectSet
oSS.Clear
Dim objcoll As ObjectCollection
objcoll = ThisApplication.TransientObjects.CreateObjectCollection
For Each oDoc In oAsmDoc.AllReferencedDocuments If oDoc.DocumentType = kPartDocumentObject Then Dim oPartDoc As PartDocument = oDoc Dim model As String = oPartDoc.DisplayName model = model & ".ipt" 'Manipulate part 'Highlight part in question For Each oOcc in oACD.Occurrences.AllReferencedOccurrences(oPartDoc)
objcoll.Add(oOcc)
Next
oSS.SelectMultiple(objColl)
ExcelFile = "F:\blablabla\Stock Parts Prices.xlsx" Dim CostTypeRow As Integer = GoExcel.FindRow(ExcelFile, "Sheet1", "Stock Type", "=", iProperties.Value(model,"Project", "Stock Number")) Dim CostType As String If CostTypeRow = -1 Then CostType = "NULL" ElseIf CostTypeRow > 0 Then CostType = GoExcel.CellValue(ExcelFile, "Sheet1", "C" & CostTypeRow) 'Look up cost of that part Cost = GoExcel.CellValue(ExcelFile, "Sheet1", "B" & CostTypeRow) End If If CostType = "POUND" Then mass = iProperties.Mass(model) TotalCost = Cost * mass iProperties.Value(model,"Project", "Estimated Cost") = TotalCost Else If CostType = "INCH" Then Try length = Parameter(model, "B_L") MessageBox.Show("Detected Length = " & Parameter(model, "B_L"), model) Catch length = InputBox("Input length of part:", iProperties.Value(model,"Summary", "Title") & " " & iProperties.Value(model,"Project", "Stock Number"), "0") End Try TotalCost = length * Cost iProperties.Value(model,"Project", "Estimated Cost") = TotalCost End If Else End If Next
oSS.Clear
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 8
Hi MechMachineMan, thanks for replying. I think I follow all the additions for the code you added, as well as the function of each line.
When I run the code now, it gives me an error:
Error on Line 7 : Type 'oAsmDoc.SelectSet' is not defined.
Is it possible it's missing a line above that defines what SelectSet is?
Message 4 of 8
MechMachineMan
Sorry, wrote that late last night.
oSS.Clear
should be
Dim oSS As SelectSet
oSS = oAsmDoc.SelectSet oSS.Clear
Justin K
Message 5 of 8
Perfect, thank you! That works like a charm. Using a selection set seems to work much better than changing the color of each component, definitely simpler.
Message 6 of 8
Hey, would it be possible to modify this code so that instead of selecting them all together as it goes through it only selects the one currently being looked at? It work would a little better for my purposes. Thank you!
Message 7 of 8
MechMachineMan
oSS.Clear
objcoll.Add(oOcc)
Next
objcoll.Clear
oSS.Clear
Next
oSS.Clear
Justin K
Message 8 of 8
RoyWickrama_RWEI
Thanks a lot. I am using your code in part of my one of rules.
It does well,but I am curious why the selected items (part or sub-assembly) look(s) different from the default blue.
'https://forums.autodesk.com/t5/inventor-customization/highlight-set/td-p/3216330
Dim iLNO As String = "0014A"
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oSelections As New ArrayList
oComp = "Component"
oPart = "Part"
oCancell = "Cancel"
oSelections.Add(oComp)
oSelections.Add(oPart)
oSelections.Add(oCancell)
Dim oSet1 As Inventor.HighlightSet
oSet1 = oDoc.CreateHighlightSet
oSet1.Clear
Dim oEntities As ObjectCollection
oEntities = ThisApplication.TransientObjects.CreateObjectCollection
oSelection = InputListBox("SELECT", oSelections, oSelections(0), Title := iLNO & ": COMPONENT SELECTION", ListName := iLNO & ": Selection List")
If oSelection = oCancell Then Exit Sub
While True
	If oSelection = oComp Then
		oEntity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, iLNO & ": Select Component:")
	Else If oSelection = oPart Then
		oEntity = ThisApplication.CommandManager.Pick(kAssemblyLeafOccurrenceFilter, iLNO & ": Select Part:")
	If IsNothing(oEntity) Then Exit While
	oSet1.AddItem(oEntity)
	oEntities.Add(oEntity)
End While
oSet1.Clear
i = 1
For Each oEntity In oSet1
	Dim oOccurrence As ComponentOccurrence
	oOccurrence = oEntity
	oDoc_Entity = oOccurrence.Definition.Document
	MsgBox(oEntities.Item(i).name _
	& vbLf & oDoc_Entity.FullFileName)
	i += 1
Next
