Pattern Explode
Pattern Explode
manikandanmmkm
Pattern Explode
manikandanmmkm
Hi
I have a pattern of iassemblies in an assembly. If I change the member then all instances will change.
So is it possible to explode/break a pattern into individual iassemblies?
MechMachineMan
This post is better suited for the general forum:
https://forums.autodesk.com/t5/inventor-forum/bd-p/78
But, I think you might be able to right click elements in the pattern and select "Independent" and that might make it work for you. But generally, you are better off only using patterns in the pattern elements are identical.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
