Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I need iLogic or VB code for :
1. add derived component Part2.ipt to Part1.ipt, I actually need only Sketch3
2. then i need to Extrude, type CUT, behavior TO NEXT, profile, from Sketch3 (circle) to Solid1 in Part1.ipt (i want to just make a hole in Part1.ipt.)
I attached two simple files. In Part1.ipt, there are derived Part2.ipt and Extrusion2 already done manually.
I want to obtain the same result with iLogic.
For clarification why i'm doing this: in fact Part2.ipt always contains complicated shapes (that i want to create only once !), then add Part1.ipt and a lot of instance Part2.ipt to ASSEMBLY.iam.
Part1.ipt it is usually a cylinder or end cap, shape is easy but there are a lot of holes (i don't want to to this manually by planes, sketech, parameters - this is a long way)
Until now, I have used the master skeleton method, but it is not satisfactory when I have to do, for example, 100 elements in a project.
