Customize user commands - button order gets flipped
Ced495
Ced495
This seems to be a bug, I was trying to set up "Customize user commands" and noticed that in some cases after clicking Apply the button order I set gets flipped, and then re-flipped another time. It goes back and forth... This becomes more of an issue when I create custom command blocks for multiple environments. Re-ordering them becomes a bigger time consumer every time I add more icons and environments.
One way to replicate issue:
1. Open "Customize user commands"
2. Add some buttons to an environment
3. Click Apply
4. Click Close
5. Open "Customize user commands"
6. Button order is flipped
7. Make some change (e.g move one button up or down)
8. Click Apply
9. Click Close
10. Open "Customize user commands"
11. Button order is flipped again
I also exported the settings at various times and noticed that the rows for those buttons are flipped back and forth in the code as well. Essentially if a change is made and applied, the button order gets flipped after reopening the Customize window.
Info:
Inventor 2020 Pro, build 239, release 2020.1.1.
Windows 10 Pro
HideoYamada
Is this related to your issue?
2020.2 Update
> UI - Customization
> Resolved issue where text on customized ribbon commands was missing and the order was reversed. INVGEN-26616
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Ced495
Thank you for the response.
I installed the update and that fixed the issue as far as I could test at the moment.
Thank you for reminding about the new update, I don't get notifications about them when they come available - even though the function is ticked in autodesk desktop app. Not that big of an issue though.
Have a good day!
