Inventor Close when I run the code
mostafamahmoudseddek94
I am writing a code trying to read the fastener size of the hole feature, the code runs well but after displaying the message, inventor crushed and suddenly close.
recurred this over and over and got the same reaction
you can see the video of what happening here :
https://autode.sk/2rl8A3X
in case you can not see the code
Sub main()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oHoleF As HoleFeatures
Set oHoleF = oDoc.ComponentDefinition.Features.HoleFeatures
MsgBox (oHoleF.Item(3).ClearanceInfo.FastenerSize)
End Sub
HideoYamada
I tried your code but a problem doesn't occurred.
Can you upload the model which you tested?
And please tell us what Inventor version are you using.
(I tested with Inventor 2020.1)
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Hi  Yamada
Currently, I am using Inventor 2019.
HideoYamada
I tried your model with Inventor 2019, and got no error/trouble. ("M10" is displayed.)
Is this trouble depending on the model?
If you try this code to the simple model (one plate and one hole), do you get same trouble?
(Of cause, the hole identifier number in the code must be changed 3 to 1.)
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
I have tried this code with a simple model (one plate and one hole) and have got the same response, what is the reason behind this?
HideoYamada
I cannot reproduce your issue in my environment, so it's difficult to help you...
Does the phenomenon change if the code is changed as follows?
Sub main()
'    MsgBox (oHoleF.Item(3).ClearanceInfo.FastenerSize)
    Debug.Print oHoleF.Item(3).ClearanceInfo.FastenerSize
End Sub
This code show the result in the Immediate window instead of the Message Box.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Thanks for helping me,
since you tried to use the 2019 version like what I do and you did not get the same error, I have tried to install the latest update for inventor which is 2019.4.2 and now the inventor works well on my Computer and this creepy error has been vanished.
