ilogic: Parameter
ilogic: Parameter
mario170979
ilogic: Parameter
mario170979
i have no idea why it's only partielly works. Following code i use in my assembly but 1 component gives out "operation aborted". When i uncomment the
MsgBox("ok " & Parameter(arg, myArray(A, 0)))
in the function it works for all components in the assembly.
Class SharedValues
Dim NumberOfParameter As Integer
Dim myArray(0,0) As String
Sub Main()
doc = ThisDoc.Document
NumberOfParameter = 0
For Each oParam In userParams
	If InStr(oParam.Name, "IEH_") <> 0 Then
	NumberOfParameter = NumberOfParameter + 1
	Else
Next
NumberOfParameter= NumberOfParameter-1
ReDim myArray(NumberOfParameter,1)
Dim i As Integer
i = 0
	If InStr(oParam.Name, "IEH_") <> 0 And i <= NumberOfParameter Then
			myArray(i,0)= oParam.Name
			Select Case oParam.units
			Case "mm"
			myArray(i, 1) = oParam.Value*10
			Case "ul"
			End Select
			i = i + 1
		Else
Next
SelectPart
End Sub
Sub SelectPart()
comps = ThisApplication.TransientObjects.CreateObjectCollection
While True
	comp = ThisApplication.CommandManager.Pick(
		SelectionFilterEnum.kAssemblyOccurrenceFilter,
		"Select a component")
	If IsNothing(comp) Then Exit While
	comps.Add(comp)
End While
For Each comp In comps
PushParameterToParts(comp.Name)
Next
End Sub
Function PushParameterToParts (arg)
Dim A As Integer
For A = 0 To NumberOfParameter
Try
Parameter(arg, myArray(A, 0)) = myArray(A, 1)
'---------------- actived the code works:      MsgBox("ok " & Parameter(arg, myArray(A, 0)))
Catch
End Try
Next
InventorVb.DocumentUpdate()
End Function
End Class
MR
Autodesk Inventor Professional 2025
Autodesk Vault Professional 2025
mario170979
found a solution
Class SharedValues
Sub Main()
userParams = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters
	Else
Next
Dim i As Integer
i = 0
			Case "mm"
			Case "ul"
			End Select
			i = i + 1
		Else
Next
SelectPart
End Sub
Sub SelectPart()
While True
	comps.Add(comp)
End While
Next
End Sub
Dim A As Integer
	Parameter.Quiet = True
Try
'MsgBox("ok " & Parameter(arg, myArray(A, 0)))
Catch
End Try
Next
End Function
End Class
MR
