Ilogic not reading my Excell file.
JorisSteurs1246
Message 1 of 23
JorisSteurs1246
Does anyone has any clue why ilogic is not reading my excell file.
When I copy the path from the rule, it will open correctly when i paste it in file explorer.
Screenshots of error box are attached.
Ilogic below.
SyntaxEditor Code Snippet
'---------start of iLogic code---------
StartRule:'read excel file
GoExcel.Open("F:\JorisTest.xlsx")
'index row 2 through 100
For rowPN = 2 To 100
'find first empty cell in column B
 If (GoExcel.CellValue("B" & rowPN) = "") Then
'create a variable for the cell value that is one row less than 'the empty cell row
    lastPN = GoExcel.CellValue("B" & rowPN - 1)
      lastDesc = GoExcel.CellValue("C" & rowPN- 1)
         Exit For
 End If
Next
'show results and ask user to confirm results
question = MessageBox.Show("PN: " & lastPN & vbLf _
&"Description: " & lastDesc & vbLf _
& "Is this correct?", "iLogic from Excel", MessageBoxButtons.YesNo )
'if answer is no
If question = vbNo Then
Goto StartRule
'if answer is yes exit rule
Else End If
Replies (22)
Message 2 of 23
MechMachineMan
GoExcel.Open("filename", “sheetname”)
http://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014/...
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 23
JorisSteurs1246
I did include the sheetname in my first attempts but when it didn't work, I started reading in the online help where is says that if there is no sheetname in the path, Inventor thakes sheet1 by default. So I gave this a try also, but no luck.  ( Sheet1 is also the name of Sheet1 in my file, so that should be OK )
Message 4 of 23
Owner2229
Hi, at the end of your rule you must have this code below. So it saves and closes the Excel table. Maybe that is the problem.
GoExcel.Save
GoExcel.Close
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 5 of 23
JorisSteurs1246
No adding this code didn't help, file is not recognized. Maybe its a Widows problem?  Are ther any tests I can do to pinpoint the issue?
Maybe it can be because of the fact that I upgraded fom office 2003 to Office 2010 while Inventor was already installed?
Message 6 of 23
MechMachineMan
http://forums.autodesk.com/t5/inventor-customization/ilogic-and-excel/m-p/4855153/highlight/true#M48...
Justin K
Message 7 of 23
MechMachineMan
http://forums.autodesk.com/t5/inventor-customization/interface-not-registered-broken-connection-with...
Justin K
Message 8 of 23
JorisSteurs1246
Copied the IPT and Excel file to another machine and still a problem although the error message is different.
Message 9 of 23
MechMachineMan
Well, what's the error there?
Justin K
Message 10 of 23
JorisSteurs1246
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
at Microsoft.Office.Interop.Excel.Workbooks.Open(String Filename, Object UpdateLinks, Object ReadOnly, Object Format, Object Password, Object WriteResPassword, Object IgnoreReadOnlyRecommended, Object Origin, Object Delimiter, Object Editable, Object Notify, Object Converter, Object AddToMru, Object Local, Object CorruptLoad)
at iLogic.GoExcel.SetCurrentSheet(String fileName, String sheetName)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Message 11 of 23
MechMachineMan
Try copy pasting the data to a new excel file on this new computer and
re-running. Looks like excel issues.
Justin K
Message 12 of 23
JorisSteurs1246
Did so already earlier,  but gave it another try right now, with this outcome.
Message 13 of 23
MechMachineMan
Try this simple rule with a new excel file and see how that goes:
Dim Loc as String = "C:/" ' Change to actual file location
Worksheet = Loc
Sheetno = ("Sheet1")
GoExcel.Open(Worksheet, Sheetno)
GoExcel.CellValue("A" & 1) = "This is working"
GoExcel.Save
GoExcel.Close
newExcelApp = CreateObject("Excel.Application")
newExcelApp.Visible = True
newExcelApp.Workbooks.Open(Loc)
Justin K
Message 14 of 23
JorisSteurs1246
No luck....   strange that the same error occurs on 2 differntr machines
Message 15 of 23
MechMachineMan
Indeed. Do you have multi langauge/cross language settings between your programs? Or is it all in english?
Justin K
Message 16 of 23
JorisSteurs1246
I used to have on both machines Office 2003 ( DUTCH)  and W7  ( ENG )
On one machine I recently uninstalled Office 2003 and replaced it with  Office 2010 ( ENG).
Message 17 of 23
MechMachineMan
Is your inventor installed on both using dutch?
This is definitely a deeper issue then what the vba is doing.
Justin K
Message 18 of 23
JorisSteurs1246
No only this MS Office I´ve installed is in Dutch because the CD doesn´t give me an other choice.
So Inventor is, and always has been, installed ENG. It might be that MS is installing patches on my PC that fit the Dutch office but whenever I´ve the choice as a user to select a language I choose ENG.
Message 19 of 23
Owner2229
Is your sheet named "Sheet1" or something else? If it is something else then try to copy it to the rule. Excel most probably named it diferently as you have it in Dutch.
Mike
Message 20 of 23
JorisSteurs1246
This ,of course, I made sure that the sheetname matchces the one used in the rule .
