Ilogic - get number of occurences from a pattern sketch driven
DominiqueBernardi5116
Good morning eveyone,
I think everything is in the title.
I'm looking for a code that can "extract" the number of occurences from a sketch driven pattern.
I've started with :
oPattern = Feature.InventorFeature("RZO")
and try to "count", but I t not be in the good direction, can someone help me plz.
Thank a lot.
bradeneuropeArthur
Do you want to count the center-points ie in the sketch or do you need to count the features in the part ie Holes?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
no matter , counting points would be perfect for me
regards
Public Sub nain()
Dim a As PartDocument
Set a = ThisApplication.ActiveDocument
Dim b As Sketch
Set b = a.ComponentDefinition.Sketches.Item(1)
MsgBox b.SketchPoints.Count
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Thanks very much.
BR
I appreciate your thanks.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
