Using second array takes the values from the first array.
Hello All,
I have been able to put together a bit of code which lets me dimension a number of holes regardless of the order in which they are placed. This works great but im having a problem when I try to add this for a second time in the same rule.
First I set up the rule and the Workpoints for holes and faces for the edges.
'Initial setup
'References this document
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisDoc.Document
'References this drawing sheet
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
'References this drawing view
Dim oView As DrawingView
oView = ActiveSheet.View("VIEW2").View
'References this drawing view Model
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ActiveSheet.View("VIEW2").ModelDocument
'Readys code for creation of reference points for dimension placement
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
'Readys code for creation of general dimensions
Dim oGeneralDims As GeneralDimensions
oGeneralDims = oSheet.DrawingDimensions.GeneralDimensions
Dim oDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
'Dimension Style:
Dim oDimStyle As DimensionStyle
Dim oStylesMgr As DrawingStylesManager = oDrawDoc.StylesManager
oDimStyle = oStylesMgr.DimensionStyles.Item("iLogic")
Dim oGeom1 As Inventor.GeometryIntent
Dim oWP101 As Inventor.WorkPoint = oDoc.ComponentDefinition.WorkPoints.Item("Gat1")
Dim oCenterMark101 As Inventor.Centermark
If Aantal_gaten > 0 Then
oView.SetIncludeStatus(oWP101, True)
oCenterMark101 = oSheet.Centermarks.AddByWorkFeature(oWP101, oView)
oGeom1 = oSheet.CreateGeometryIntent(oCenterMark101, kPoint2dIntent)
oCenterMark101.Visible = False
Dim oGeom2 As Inventor.GeometryIntent
Dim oWP102 As Inventor.WorkPoint = oDoc.ComponentDefinition.WorkPoints.Item("Gat2")
Dim oCenterMark102 As Inventor.Centermark
If Aantal_gaten > 1 Then
oView.SetIncludeStatus(oWP102, True)
oCenterMark102 = oSheet.Centermarks.AddByWorkFeature(oWP102, oView)
oGeom2 = oSheet.CreateGeometryIntent(oCenterMark102, kPoint2dIntent)
oCenterMark102.Visible = False
Dim oGeom3 As Inventor.GeometryIntent
Dim oWP103 As Inventor.WorkPoint = oDoc.ComponentDefinition.WorkPoints.Item("Gat3")
Dim oCenterMark103 As Inventor.Centermark
If Aantal_gaten > 2 Then
oView.SetIncludeStatus(oWP103, True)
oCenterMark103 = oSheet.Centermarks.AddByWorkFeature(oWP103, oView)
oGeom3 = oSheet.CreateGeometryIntent(oCenterMark103, kPoint2dIntent)
oCenterMark103.Visible = False
'Etc............... (x20)
oObjs = oAssyDoc.AttributeManager.FindObjects("RH_links","RH_links","1")
aoEdge01 = oObjs.Item(1)
oObjs = oAssyDoc.AttributeManager.FindObjects("RH_rechts","RH_rechts","1")
aoEdge02 = oObjs.Item(1)
oDrawViewCurves = oView.DrawingCurves(aoEdge01)
aoDrawCurves01 = oDrawViewCurves.Item(1)
oDrawViewCurves = oView.DrawingCurves(aoEdge02)
aoDrawCurves02 = oDrawViewCurves.Item(1)Then I place the holes from smallest to biggest and create dimensions between The edges and all the holes.
Dim oArray As New ArrayList
Dim i As Integer
Dim oG(0 To 19) As Inventor.GeometryIntent
'[Sorteer gaten
Dim oGatB(0 To 19) As Double
oGatB(0) = B1
oGatB(1) = B2
oGatB(2) = B3
oGatB(3) = B4
oGatB(4) = B5
oGatB(5) = B6
oGatB(6) = B7
oGatB(7) = B8
oGatB(8) = B9
oGatB(9) = B10
oGatB(10) = B11
oGatB(11) = B12
oGatB(12) = B13
oGatB(13) = B14
oGatB(14) = B15
oGatB(15) = B16
oGatB(16) = B17
oGatB(17) = B18
oGatB(18) = B19
oGatB(19) = B20
For i = 0 To 19 Step 1
If Aantal_gaten > i Then
oArray.Add(oGatB(i))
Next
oArray.Sort()
'[Plaats maatvoering vanaf de linker rand naar het eerste gat
Select Case oArray(0)
Case B1
oG0 = oGeom1
Case B2
oG0 = oGeom2
Case B3
oG0 = oGeom3
Case B4
oG0 = oGeom4
Case B5
oG0 = oGeom5
Case B6
oG0 = oGeom6
Case B7
oG0 = oGeom7
Case B8
oG0 = oGeom8
Case B9
oG0 = oGeom9
Case B10
oG0 = oGeom10
Case B11
oG0 = oGeom11
Case B12
oG0 = oGeom12
Case B13
oG0 = oGeom13
Case B14
oG0 = oGeom14
Case B15
oG0 = oGeom15
Case B16
oG0 = oGeom16
Case B17
oG0 = oGeom17
Case B18
oG0 = oGeom18
Case B19
oG0 = oGeom19
Case B20
oG0 = oGeom20
End Select
oPt = oTG.CreatePoint2d(oView.Left + (oView.Width / 2), oView.Top - oView.Height - 1.5)
oDim = oGeneralDims.AddLinear(oPt, oSheet.CreateGeometryIntent(aoDrawCurves01), oG0, DimensionTypeEnum.kHorizontalDimensionType)
oDim.Style = oDimStyle
oDimAtt = oDim.AttributeSets.Add("iLogic_Created")
oStart = oG0
'[Plaats maatvoering tussen gaten
For i = 1 To oArray.Count - 1 Step 1
Select Case oArray(i)
Case B1
oG(i) = oGeom1
Case B2
oG(i) = oGeom2
Case B3
oG(i) = oGeom3
Case B4
oG(i) = oGeom4
Case B5
oG(i) = oGeom5
Case B6
oG(i) = oGeom6
Case B7
oG(i) = oGeom7
Case B8
oG(i) = oGeom8
Case B9
oG(i) = oGeom9
Case B10
oG(i) = oGeom10
Case B11
oG(i) = oGeom11
Case B12
oG(i) = oGeom12
Case B13
oG(i) = oGeom13
Case B14
oG(i) = oGeom14
Case B15
oG(i) = oGeom15
Case B16
oG(i) = oGeom16
Case B17
oG(i) = oGeom17
Case B18
oG(i) = oGeom18
Case B19
oG(i) = oGeom19
Case B20
oG(i) = oGeom20
End Select
If oArray(i) <> oArray(i - 1) Then
oDim = oGeneralDims.AddLinear(oPt, oStart, oG(i), DimensionTypeEnum.kHorizontalDimensionType)
oStart = oG(i)
'MsgBox(oArray(i).ToString)
Next
'Plaats de maatvoering van het laatste gat naar de rechter rand
oDim = oGeneralDims.AddLinear(oPt, oSheet.CreateGeometryIntent(aoDrawCurves02), oStart, DimensionTypeEnum.kHorizontalDimensionType)
oDimAtt = oDim.AttributeSets.Add("iLogic_Created")No problem so far, but now i want to not only dimension the width but also the height. So I copy and paste the last part and change all the needed variables to get the following.
'[Sorteer gaten
Dim oGatH(0 To 19) As Double
oGatH(0) = H1
oGatH(1) = H2
oGatH(2) = H3
oGatH(3) = H4
oGatH(4) = H5
oGatH(5) = H6
oGatH(6) = H7
oGatH(7) = H8
oGatH(8) = H9
oGatH(9) = H10
oGatH(10) = H11
oGatH(11) = H12
oGatH(12) = H13
oGatH(13) = H14
oGatH(14) = H15
oGatH(15) = H16
oGatH(16) = H17
oGatH(17) = H18
oGatH(18) = H19
oGatH(19) = H20
oArray.Add(oGatH(i))
Next
'[Plaats maatvoering naar eerste gat
Case H1
oG0 = oGeom1
Case H2
oG0 = oGeom2
Case H3
oG0 = oGeom3
Case H4
oG0 = oGeom4
Case H5
oG0 = oGeom5
Case H6
oG0 = oGeom6
Case H7
oG0 = oGeom7
Case H8
oG0 = oGeom8
Case H9
oG0 = oGeom9
Case H10
oG0 = oGeom10
Case H11
oG0 = oGeom11
Case H12
oG0 = oGeom12
Case H13
oG0 = oGeom13
Case H14
oG0 = oGeom14
Case H15
oG0 = oGeom15
Case H16
oG0 = oGeom16
Case H17
oG0 = oGeom17
Case H18
oG0 = oGeom18
Case H19
oG0 = oGeom19
Case H20
oG0 = oGeom20
End Select
oPt = oTG.CreatePoint2d(oView.Left + oView.Width + 1.5, oView.Top - (oView.Height / 2))
oDim = oGeneralDims.AddLinear(oPt, oSheet.CreateGeometryIntent(aoDrawCurves01), oG0, DimensionTypeEnum.kVerticalDimensionType)
oStart = oG0
Case H1
oG(i) = oGeom1
Case H2
oG(i) = oGeom2
Case H3
oG(i) = oGeom3
Case H4
oG(i) = oGeom4
Case H5
oG(i) = oGeom5
Case H6
oG(i) = oGeom6
Case H7
oG(i) = oGeom7
Case H8
oG(i) = oGeom8
Case H9
oG(i) = oGeom9
Case H10
oG(i) = oGeom10
Case H11
oG(i) = oGeom11
Case H12
oG(i) = oGeom12
Case H13
oG(i) = oGeom13
Case H14
oG(i) = oGeom14
Case H15
oG(i) = oGeom15
Case H16
oG(i) = oGeom16
Case H17
oG(i) = oGeom17
Case H18
oG(i) = oGeom18
Case H19
oG(i) = oGeom19
Case H20
oG(i) = oGeom20
End Select
oDim = oGeneralDims.AddLinear(oPt, oStart, oG(i), DimensionTypeEnum.kVerticalDimensionType)
oStart = oG(i)
Next
oDim = oGeneralDims.AddLinear(oPt, oSheet.CreateGeometryIntent(aoDrawCurves02), oStart, DimensionTypeEnum.kVerticalDimensionType)
']I think I have changed everything I need to change in this second part to be able to but this ends up happening and I receive an error.
When I check what is happening with a messagebox it seems like after the first correctly used hole in the array it takes the second and all following holes from the first array.
This is not a big probelem since I have been able to just put them in two seperate rules and make it work but it would be nice to know a way to get them both to be in the same rule and functioning in the future.
Thanks in advance,
Jeffrey
