ilogic Functions &/Or Sub Routines Passing Arguments Back To Main Code
Tim_Mulder
Tim_Mulder
Hello All,
I'm struggling to understand Functions &/Or Sub Routines in ilogic.
In effect I am trying to have a function/sub routine within my code that stores a list of integers.
Then I want return some of those integers (with some if else statements) to my called function/sub routine so Ican use these values elsewhere. I have a rough idea of how functions work in VBA but that doesn't seem to translate to ilogic, unless I am missing something. Here is what I have so far
Sub Main
Call SplitPinCalc((BoltSize), Split_Pin, Split_Pin_Hole, Split_Pin_Dist)
'These values above don't update with function values below
End Sub
Function SplitPinCalc(BoltSize As Integer, Split_Pin As Integer, Split_Pin_Hole As Integer, Split_Pin_Dist As Integer)
If BoltSize = "12" Then
	Split_Pin = 3
	Split_Pin_Hole = 4
	Split_Pin_Dist = BoltSize*2
Else If 'Blah Blah Blah
Return SplitPinCalc
End Function
My code so far enters into the function and works as intended, but those values are not passed back up to the called function arguments.
Any help & instruction would be much appreciated.
Kind Regards
Tim
bradeneuropeArthur
What would you like to be returned for the function:
Split_Pin = 3
	Split_Pin_Hole = 4
	Split_Pin_Dist
This function can only return one value.
If you need more you need to create a Class.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
This is how it works in basics
Public Sub main()
MsgBox a(2)
End Sub
Private Function a(b As Integer) As Integer
If b = 1 Then
a = 11
If b = 2 Then
a = 22
End Function
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Curtis_Waguespack
Hi @Tim_Mulder ,
Welcome to the forum. In addition to the previous replies, this simple example might help illustrate the use of a function.
I hope this helps.
Curtis
Sub Main
'basket 1
Apples = 10
Oranges = 10
'get qty of basket1
Basket1 = QTY_Fruit( Apples, Oranges)
'basket 2
Apples = 2
Oranges = 3
'get qty of basket2
Basket2 = QTY_Fruit( Apples, Oranges)
MsgBox(Basket1 + Basket2 & " total pcs")
End Sub
Function QTY_Fruit(A As Integer, O As Integer )
	'calc fruit
	oQTY = A + O
	'send sum back to main sub
	Return oQTY
End Function
and here is a slightly different way of doing this based on the syntax that bradeneuropeArthur 's example used to write and return the function.
Sub Main
'basket 1
Apples = 10
Oranges = 10
'get qty of basket1
'basket 2
Apples = 2
Oranges = 3
End Sub
Function QTY_Fruit (A As Integer, O As Integer ) As Integer
	'calc fruit
	QTY_Fruit = A + O
End Function
Tim_Mulder
Thanks for your reply,
Please find in picture what I'm intending the function or sub to achieve.
I have the feeling I may be trying to do something the Function can't handle.
Thanks for the help.
Regards
Tim
laszlo_nagy
Hi!
Try  this
Sub Main
Dim Spin_Pin As Integer = 0
Dim Spin_Pin_Hole As Integer = 0
Dim Spin_Pin_Dist As Integer = 0
'Array
Dim result(2) As Integer
'Call the Function
result = SplitPinCalc(12)
'Store the results
Spin_Pin = result(0)
Spin_Pin_Hole = result(1)
Spin_Pin_Dist = result(2)
'Display the Result
MessageBox.Show("Pin is:" & Spin_Pin & " - Hole is:" & Spin_Pin_Hole & " - Distance is:" & Spin_Pin_Dist )
End Sub
Function SplitPinCalc(Boltsize As Integer) As Integer()
	Dim fResult(2) As Integer
	'Condition
	If Boltsize = 12 Then
		fResult(0) = 3 'Pin
		fResult(1) = 4 'Hole
		fResult(2) = Boltsize * 2 'Dist
	'Return Value (Array)
	SplitPinCalc = fResult
End Function
