iLogic Error - On 2nd PC
I have this iLogic rule that picks up the File name a custom properties. And this works fine on my PC, but it is not working a different PC with the same template files and ilogic rule, any body know why?
Rule Below:
SyntaxEditor Code Snippet
Sub Main()
'Purpose: Push file name to sheet name'21-Sept-16
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oDrawingView As DrawingView
'Iterate through sheets
For Each oSheet In oDoc.Sheets
    'Grab the first drawing view on the sheet
    oDrawingView = oSheet.DrawingViews(1)
    'Grab the model of the first drawing view
    oModel = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
    'Grab the custom iproperty of the first drawing view model
    oModel1 = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
    o_iProp = iProperties.Value(oModel1, "Custom", "RevisionUK")
    'set sheet name to filename and custom iprop from model
    oSheet.Name = System.IO.Path.GetFileNameWithoutExtension(oModel.FullFileName)& " - " & o_iProp
Next
End Sub
Error Message
MechMachineMan
Might be a long shot, but try making sure your window "Hide known file extensions" setting is the same.
Otherwise, it might be if there is a different O/S?
Could also be some iLogic settings or something.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
where do i find this setting?
Martin-Winkler-Consulting
HI @Anonymous
for debugging the reason you can use  MsgBox to look wether the path and name is fine.
MsgBox(oModel.FullFileName)
MsgBox(System.IO.Path.GetFileNameWithoutExtension(oModel.FullFileName)) oSheet.Name = System.IO.Path.GetFileNameWithoutExtension(oModel.FullFileName)& " - " & o_iProp
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
